Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
Awsome Top Fuel dragster specs
Old 12-12-2006, 10:08 PM   #1
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 39 Andrew is just really niceAndrew is just really niceAndrew is just really niceAndrew is just really nice
Send a message via AIM to Andrew
Default Awsome Top Fuel dragster specs
# One Top Fuel dragster's 500-cubic-inch Hemi engine makes more horsepower than the first four rows at the Daytona 500.
# A stock Dodge Hemi V-8 engine cannot produce enough power to drive the dragster's supercharger.
# With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
# At the stoichiometric 1.7:1 air-fuel mixture for nitro methane, the flame front temperature measures about 7000 degrees Fahrenheit.
# Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, separated from atmospheric water vapor by the searing heat of the exhaust gases.
# Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
# Spark plug electrodes can be totally consumed during a single pass. After half-distance, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees Fahrenheit. The engine is shut down by cutting the fuel flow.
# If a spark plug fails early in the run, un-burned nitro can build up in the affected cylinder and explode with sufficient force to blow the cylinder head off in pieces or split the cylinder block in half.
# In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate at an average of more than 4 g's. In order to reach 200 mph before half-distance, the launch acceleration approaches 8 g's. A Top Fuel dragster reaches more than 300 mph before you have completed reading this sentence.
# With a redline that can be as high as 9500 rpm, Top Fuel engines turn approximately 540 revolutions from light to light. Including the burnout, the engine needs to survive only 900 revolutions under load.
# Assuming that all of the equipment is paid off, the crew works gratis, and nothing breaks, each run costs an estimated $1000 per second.
# The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter-mile (October 5, 2003, Tony Schumacher). The top-speed record is 333.25 mph as measured over the last 66 feet of the quarter-mile (November 9, 2003, Doug Kalitta).
# Putting all of this into perspective: You are driving the average $140,000 Lingenfelter twin-turbo Corvette Z06. More than a mile up the road, a Top Fuel dragster is staged and ready to launch down a measured quarter-mile as you pass. You have the advantage of a flying start. You run the Vette up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The "tree" goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down, but you hear a brutal whine that sears your eardrums, and within three seconds, the dragster catches you and beats you to the finish line, a quarter-mile from where you just passed him. From a standing start, the dragster spotted you 200 mph and not only caught you but nearly blasted you off the road when he passed you within a mere 1320 feet.
1991 CRX Si -Turbo z6 - if I can ever finish...
2007 Civic Si Sedan - Stock DD
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 12-13-2006, 09:22 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Rep Power: 529 pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
but cool info nonetheless
Old 12-13-2006, 04:58 PM   #3
I DonkeyPunch Hypocrites
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 92 BMW 318is
Rep Power: 107 B16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
I think if one of those gives me a lead like he'd give that Ligenfilter ZO6, I could take'em easy in my CRX...
Now that Obama, a (half) Black man, is the President, I don't want to hear anymore about this so-called 'man' who's been holding your lazy ass back. Go get a damn job...
B16RacerN2NR is offline   Reply With Quote
Old 12-13-2006, 06:39 PM   #4
Citizen_Insane's Avatar
Rep Power: 48 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
-Yet another reason drag racing is stupid.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 12-13-2006, 07:09 PM   #5
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 122 klyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
Build an engine to take maximum abuse, and then actually GIVE it maximum abuse. Heads exploding, Fireballs of death and debris, still sounds cool to me.
My Project
1978 Honda Civic D16A1 swap - IT IS ALIVE!
Do not PM me with tech questions. I will NOT know the answer.
Originally Posted by formby View Post
I've come to the conclusion that a family is the one you make not the one your born into.
klyph is offline   Reply With Quote
Old 12-14-2006, 07:33 AM   #6
Andrew's Avatar
Ride:  1991 CRX Si
*ahh* i love it.
Heres some more facts:
If the driver pulls the parachute while still accelerating, chances are his/her retina's will disconnect from the negative G's.
Also, if the driver is not as far back in his seat as possible, braced, the force of the launch can also dissconnect the retina.
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 12-14-2006, 10:04 PM   #7
Speedracer228's Avatar
Rep Power: 25 Speedracer228 is on a distinguished road
Send a message via AIM to Speedracer228
"# Putting all of this into perspective: You are driving the average $140,000 Lingenfelter twin-turbo Corvette Z06. More than a mile up the road, a Top Fuel dragster is staged and ready to launch down a measured quarter-mile as you pass. You have the advantage of a flying start. You run the Vette up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The "tree" goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down, but you hear a brutal whine that sears your eardrums, and within three seconds, the dragster catches you and beats you to the finish line, a quarter-mile from where you just passed him. From a standing start, the dragster spotted you 200 mph and not only caught you but nearly blasted you off the road when he passed you within a mere 1320 feet."
Id like to see this played out.. on the next Top Gear maybe? lol That would be quite a vid to see if that would really happen.
Speedracer228 is offline   Reply With Quote
Old 12-14-2006, 11:01 PM   #8
Cogito Ergo Sum Steampunk
Celerity's Avatar
Ride:  1972 Plymouth Satellite, 1982 Chevy truck, 1987 Jeep Wrangler, 1987 CRXSi,
Rep Power: 299 Celerity has a reputation beyond reputeCelerity has a reputation beyond repute
Celerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond repute
Send a message via AIM to Celerity Send a message via MSN to Celerity myspace
Top gear did an awesome comparo with the Skyline vs a McLaren F1. Then they compared that test (Not visually) with the Veyron. I think it went something like this:
a McLaren can do the 1/4 mile and come to a complete stop before the Skyline makes the full run.
A Bugatti Veyron can do 0 to top speed and back in the amount of time it would take the McLaren to do that same run.
There were a few more neat things about the Veyron... Top Gear titled it "a rolling superlative".
Things like the gas tank size was carefully measured to give the Veyron a top-speed run for 12 seconds before running out of fuel. That car is fuckin crazy.
Originally Posted by SlushboxTeggy View Post
Cel is the biggest pussy and the biggest bad ass at the same time. He is enlightened and not . He can go after someones mind with scalpel like precision or smash their head in with a rock tied on a stick. The best way to describe him... He is an enigma.
Celerity is offline   Reply With Quote
Forum Jump
Tips to Help you Change a Fuel Filter on a 1994 Accord JohnnyWadd General Tech Articles 1 08-22-2006 07:39 PM
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 11:09 PM
Drag kit install manual pissedoffsol Forced Induction 0 07-18-2004 12:37 AM
research paper, what do you think? 90 accord Members' Lounge 9 06-23-2004 12:11 AM
Interesting facts about top fuel dragsters. Loco Honkey Members' Lounge 24 11-23-2003 08:39 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
