So when I bought the 97 S14 and sold the 99 SI one of the long term bennifet's I cited in my decision was that owning it wouldhelp me to learn more about working on cars. For those of you who don't know I was an aircraft mechanic for 6 years so mechanic repair isn't hard for me I just don't have allot of experience doing it with cars. Or rather I should say didn't lol.
Since I bought it: Tie Rods Front Lower Ball Joints Front Cover Seal Alternator Waterpump I'm sure I left something out, but everytime the process is the same, I find someone who can tell me what's wrong, I buy the part, locate it under the hood, and change it no prob lol. Well here's he latest problem In the last 700 miles or so my fuel economy has sank from 22 all way way to 16MPG some useful info Spark plugs are plat and 2 years old Wires looked new when I bought the car two years ago vehicle runs smoothly I use 92 octane Fuel Filter is a year old There is obviously no leak, I'm not a dumb ass Any idea what's wrong? __________________
Did I just say something interesting or funny? Check out my blog for more... http://campassmore.wordpress.com/ |
Main causes of poor gas mileage are as follows...
#1 = Plugs & Wires #2 = Air Filter #3 = Fuel Filter #4 = TIRE PRESSURE (This kicks alot of people in the ass) #5. Depleted Oil Quality (Motor/Tranny/Diff) __________________
this country is turning into a bunch of fucking pussies... if this keeps up, pretty soon we'll be singing the french national anthem. -E_SolSi |
#4 | |
Cogito Ergo Sum Steampunk
Blowby.
#5 | |
Actually, I take that back . ECU can do it too. The Neon will get 30 mpg one tank full, 19 the next. I have no idea why. Then it gets back up. Last tank I averaged 26 mpg and the one before that I made it to 32. This tank I'm going to take to a hair over 200 mpg which is less than 20 mpg. (My alternator shit the bed in the middle of Rural Connecticut late at night, had to hammer that shit home)
#6 |
do you warm up your car before you drive it?? i usually see 27-30 around town, but last winter when i used my car a lot more and warmed it up most of the time, it was down to below 20.
im sure if you did that youd realize it, but hey.. who knows. :P __________________
My name is Sean.
#7 | |
Member of the 20 nut club
cold weather makes the car run a richer AFR
letting the car idle for 30 minutes warming it up every morning before work kills your MPG in the winter gas companies add more ethanol to the mix to "keep gas lines from freezing"... more ethanol makes the car run richer AFRs, it also burns less efficiently, it also creates less power forcing you to drive harder to try and get the same performance out of the car so ethanol = richer AFR = lower MPG , less eficient burn = lower MPG, less power = drive harder = lower MPG and just for shits and giggles while im on the subject... ethanol not only kills your MPG, its also a lot harsher on your entire fuel system (pump, lines, injectors, etc...), and it will reduce the lifespan of your engine significantly yay ethanol!!! __________________
МОΛΏΝ ΛΑΒΈ |
#8 | |
When I filled up yesterday I was a quart low on oil but.. nahhh air filter was recharged a month or so ago tire pressure is fine fuel filter is a year and a half old I do warm my car up every morning though, for about 15min or so I have a new PCV valve too, doubt it would help much cause the vehicle is running smoothily but I have it laying around so I guess I'll change that out too any other ideas? __________________
#9 | |
Warm ups will do it too.. although I have no idea why, really.
#10 |
but this is only during winter? I have owned this car for going on three years in March and I've never noticed this before
#11 |
Oh, and I started using COSTCO gas too
#12 |
Ride: 2006 Audi A4
Depending on the setup, when its cold their could be fuel economy problems as well.
I pull the tumbler generator valves from the WRX that help on cold start ups, the weather gets cold, and my gas mileage shoots into the shitter. Also, with forced induction you may be boosting that much more and that much harder now that the humidity has dropped and its so cold. Have you datalogged anything? If I were you, I'd start with plugs and wires/coil packs (I'm not familiar with the sr so I don't know what it runs). Tire pressure is another obvious thing. I'd personally check for boost leaks as well, just to make sure that you're not feeding the car a ton of gas, only to have power robbed from the car through a vacuum/boost leak. __________________
"Good talk... I'll see you out there." |
#13 |
Ride: 2006 Audi A4
Haven't you heard that brand of gas means virtually nothing? All gas is brought in by ship or pipeline by a few key players and divvied up between oil companies. Its the same shit, different day. Some places like Hess and Mobile add their detergents and additives but really there's no such thing as one retailer having "bad gas" on a regular basis.
They actually say to go to the busiest gas station because the tanks will be filled the most often and then you won't have to worry about getting any sludge from the bottom of the tanks or any old gas. __________________
#14 | |
#15 |
Ride: 2006 Audi A4
...I thought you swapped a Sr into it last year.
I thought both you and get_nick had sr20'd 240's. ![]() __________________
#16 |
nope had a major career change, wanna buy a pickup at the end of 07, will gut the S14 and do it right
| Tips to Help you Change a Fuel Filter on a 1994 Accord | JohnnyWadd | General Tech Articles | 1 | 08-22-2006 07:39 PM |
| fuel injector problem | Supadax | HYBRID -> BA-BB /CA-CD | 7 | 07-25-2005 05:22 PM |
| zc swap into 85 crx? | devnjeff | HYBRID -> ED-EF / DA | 4 | 07-10-2005 11:09 PM |
| Help on this fuel regulator gauge | Teambypass | HYBRID -> EG-EK / DC | 5 | 09-22-2003 02:02 PM |
| Fuel Economy | kimchimik | General Tech and Maintenance | 11 | 10-21-2002 03:37 PM |
