Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
Geo Tracker 8 valve block 16 valve head
Old 11-01-2006, 09:54 AM   #1
TTIWWOP
reckedracing's Avatar
Ride:  1990 sohc vtec-t hatch, 1994 Bagged S10, 1991 Lifted Mazda
Rep Power: 228 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
Default Geo Tracker 8 valve block 16 valve head
I am looking for info on this head swap
background
16 valve MPFI tracker motor = G16A
bottom end is shot
have a good 8 valve TBI motor
8 valve and 16 valve have diffrent valve reliefs in the pistons
put the head on, timing belt
seems to turn over with no clearance issues
anyone know anything about this?
reckedracing is offline   Reply With Quote
Old 11-01-2006, 11:31 AM   #2
Cashizslick's Avatar
Rep Power: 69 Cashizslick has much to be proud ofCashizslick has much to be proud ofCashizslick has much to be proud ofCashizslick has much to be proud ofCashizslick has much to be proud ofCashizslick has much to be proud ofCashizslick has much to be proud of
Just throw a rotory in it
Cashizslick is offline   Reply With Quote
Old 11-01-2006, 08:17 PM   #3
Cogito Ergo Sum Steampunk
Celerity's Avatar
Ride:  1972 Plymouth Satellite, 1982 Chevy truck, 1987 Jeep Wrangler, 1987 CRXSi,
Rep Power: 299 Celerity has a reputation beyond reputeCelerity has a reputation beyond repute
Celerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond repute
Send a message via AIM to Celerity Send a message via MSN to Celerity myspace
What year are these motor / head combos ? I know this stuff, but only by year.
Also, I thought my gf's Tracker had a SOHC, but after close inspection (Yeah, I know.. it sounds strange) it turned out to be a staggered DOHC.
As I know, lots of these motors cross-over from other years that you wouldn't think. Even the VW Diesel swaps are neat.
Originally Posted by SlushboxTeggy View Post
Cel is the biggest pussy and the biggest bad ass at the same time. He is enlightened and not . He can go after someones mind with scalpel like precision or smash their head in with a rock tied on a stick. The best way to describe him... He is an enigma.
Celerity is offline   Reply With Quote
Old 11-07-2006, 01:53 PM   #4
TTIWWOP
well, it turns out it did work
it was a 94 MPFI 16 valve tracker
book said stock compression is 190, minimum is 170
this one had about 100 across the board
we picked up a 92 auto for a hundred bucks but it was TBI 8 valve
so we decided it would be a good field/woods car
it was a damn good runner too, but started puking auto trans fluid
so we decided to call auto zone and get head gasket part numbers for the 2 models
same headgasket
so we pulled the 92 8 valve
found out the front trans seal had just spun out thus the trans fluid leak
so we ripped the 92 motor down to swap out the 8 valve block as the rings were smoked out of the 94 block
once we got the 94 motor out and the head off we noticed the diffrence in valve releifs in the pistons them selves
fuck it, threw the head on with a timing belt and it spun over with no interferance so we figured we'd try it
needed to use the 16v timing belt cause its longer and also wider so we needed the 16v crank gear and tensioner
everything else went together very well and its runs and has a decent amount of power
swap complete
Old 11-07-2006, 08:59 PM   #5
Rep Power: 31 NissanNiNjA2nd is a jewel in the roughNissanNiNjA2nd is a jewel in the roughNissanNiNjA2nd is a jewel in the roughNissanNiNjA2nd is a jewel in the rough
I salute your grassroots power.
NissanNiNjA2nd is offline   Reply With Quote
Old 11-08-2006, 10:12 AM   #6
TTIWWOP
thanks
Old 04-09-2007, 09:15 PM   #7
Rep Power: 0 phat87mazdarx7 is on a distinguished road
Default my mom just got a tracker too
I am just curious how did you get it to run, did you use the original throttle body injection or did you wire in the multi port some how.
phat87mazdarx7 is offline   Reply With Quote
Old 04-10-2007, 09:06 PM   #8
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 122 klyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
The Tracker was originally MPFI. He put the TBI short block in it.
It's in the thread.
My Project
1978 Honda Civic D16A1 swap - IT IS ALIVE!
Do not PM me with tech questions. I will NOT know the answer.
Originally Posted by formby View Post
I've come to the conclusion that a family is the one you make not the one your born into.
klyph is offline   Reply With Quote
Old 04-10-2007, 10:52 PM   #9
but im saying what car is running now, is it the car with the mpi or the tbi?
if it was the tbi car how did you change out for the mpi
Old 04-11-2007, 03:21 AM   #10
Dismember
bottom end is shot
It's in the thread.
My Project
Forum Jump
F22xx block with h23 head d112crzy HYBRID -> BA-BB /CA-CD 13 07-14-2008 07:55 PM
FS: B20 BLOCK AND P8R HEAD erebunicrx Parts: For Sale/Trade/Wanted 8 03-04-2007 10:40 PM
D16Y7 Block + D16Z6 Head for '95 Del Sol jisakson HYBRID -> EG-EK / DC 4 07-29-2006 05:40 PM
B16 Head On An Old 1990 Integ Block numberonepimpsta HYBRID -> EG-EK / DC 6 06-22-2003 01:58 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
