Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
Hey all I own a DSM 1g eagle talon tsi AWD turbo 14b
Old 10-17-2007, 09:02 PM   #1
Grandpa
88blacksi's Avatar
Rep Power: 5 88blacksi is on a distinguished road
Default Hey all I own a DSM 1g eagle talon tsi AWD turbo 14b
I have owned this car for a month now and my crankshaft is vibrating over 14 psi of boost. I have heard the term crankwalk. But anyone have an online shop manual?
88blacksi is offline   Reply With Quote
Old 10-18-2007, 12:26 AM   #2
99sidude's Avatar
Ride:  93 DX Hatch
Rep Power: 28 99sidude is a glorious beacon of light99sidude is a glorious beacon of light99sidude is a glorious beacon of light99sidude is a glorious beacon of light
Send a message via AIM to 99sidude
i didnt think 1g dsm's had this problem
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 10-18-2007, 02:16 PM   #3
Cogito Ergo Sum Steampunk
Celerity's Avatar
Ride:  1972 Plymouth Satellite, 1982 Chevy truck, 1987 Jeep Wrangler, 1987 CRXSi,
Rep Power: 299 Celerity has a reputation beyond reputeCelerity has a reputation beyond repute
Celerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond repute
Send a message via AIM to Celerity Send a message via MSN to Celerity myspace
a built CRX, Built DSM, two BMWs ?
More money than mechanical abilities, eh ?
Originally Posted by SlushboxTeggy View Post
Cel is the biggest pussy and the biggest bad ass at the same time. He is enlightened and not . He can go after someones mind with scalpel like precision or smash their head in with a rock tied on a stick. The best way to describe him... He is an enigma.
Celerity is offline   Reply With Quote
Old 10-18-2007, 10:14 PM   #4
Ride:  1998 Eclipse GSX
Rep Power: 19 silver is on a distinguished road
Send a message via AIM to silver
You instantly diagnosed a vibration as the crankshaft vibrating? There is no online shop manual, only one on CD floating around somewhere. Easier to go buy one.
silver is offline   Reply With Quote
Old 10-21-2007, 02:37 AM   #5
Ride:  honda?duh?
Rep Power: 3 civic4g63 is on a distinguished road
[quote=88blacksi;879992]I have owned this car for a month now and my crankshaft is vibrating over 14 psi of boost. I have heard the term crankwalk. But anyone have an online shop manual?[/
1g dsm's dont get crankwalk, u will need a new crank pulley, happened to my dsm too
civic4g63 is offline   Reply With Quote
Old 11-01-2007, 04:58 PM   #6
Rep Power: 0 MrRide2Low is on a distinguished road
correction , 1g's do get crankwalk, it's less common with the early 6 bolt block and in 92.5 they changed over the 7 bolt which is generally know as the crankwalk king, the main reason for the crank walk problem is the use of very high pressure clutch plates, which pushed the crank into the trust bearing, and when you start your car with it the clutch pressed then your turning the crank against the trust bearing with no oil pressure for a short time which helps wear out the trust bearing to the point of crankwalk. check out dsmtalk.com and dsmtuners.com, they are very knowledgeable on those boards once you get past the noobs
MrRide2Low is offline   Reply With Quote
Old 11-07-2007, 09:15 PM   #7
Grandpa
88blacksi's Avatar
My friend said that I have to remove balance shaft. Where the hell is this?
Old 11-08-2007, 01:16 AM   #8
It's on the back of the block near the bottom. Unless your balance shaft belt actually broke and is just hanging there, that's not the cause.
Old 11-09-2007, 09:01 PM   #9
Grandpa
88blacksi's Avatar
i checked it and its hanging like a booger off someones nose. Like that one episode of FAMILY GUY when peter hangs off george washingtons nose when he tries to save lois after a vacation. Anyways I will buy a kit to remove these crap.will post results keep in touch thaks
Old 11-09-2007, 10:57 PM   #10
you have to remove the block from the car to install the balance shaft removal kit, it can be done in the car but good luck, it's one notch down from inpossable, also becare full on whicj kit you buy, i suggest the kit from slowboyracing.com, it's all mitsu parts, noone of that after market crap that dsm's hate
Old 11-09-2007, 11:05 PM   #11
girly.
britchick2203's Avatar
Ride:  94 hatch
Rep Power: 6 britchick2203 will become famous soon enough
Send a message via AIM to britchick2203 myspace
if you need a balance shaft eliminator kit i have a brand new one that i'm trying to sell because i don't need it.
...needs to get rid of a ton of stuff.
http://hondaswap.com/parts-sale-trad...m-parts-95873/
WTB: power window conversion...door panels/motors/switches, for my hatch.
britchick2203 is offline   Reply With Quote
Old 11-11-2007, 07:09 PM   #12
Grandpa
88blacksi's Avatar
pics i saw one for $20 used craigs
Old 11-11-2007, 07:15 PM   #13
girly.
Ride:  94 hatch
never used.
Old 11-12-2007, 01:49 PM   #14
^^ the stub shaft doesn't have the oil ring like the oem pieces
view pic here http://http://www.slowboyracing.com/...at=1060&page=1
Old 11-12-2007, 09:28 PM   #15
Grandpa
88blacksi's Avatar
site no workie
Old 11-12-2007, 09:29 PM   #16
Grandpa
88blacksi's Avatar
never used.
never used I buy used and remanufacture it
Old 11-12-2007, 09:45 PM   #17
Grandpa
88blacksi's Avatar
I rebuilt and use it
Old 11-12-2007, 09:56 PM   #18
Rep Power: 7 tofasttoslowforyou is on a distinguished road
Crankwalk is caused by the thrust bearings prematurely wearing out, and since the 7 bolts oil galleries are not tapped for the piston oil squirter's the only way it cools the pistons is by an extra hole drilled in the connecting rod to squirt oil on the piston, this puts a big amount of strees on the main gallery since it also lubes the thrust washer.
you can tell if you have a 7 or 6olt dsm by the shape of the oil pan on the timming side or the timming cover or the bolts in the flywheel.
If it is crank walk you can drop the oil pan and check the trust washers or try to move the crank in or out this will let you know if the thrust washers are going and hence crank walk.
Check your belts pulleys and motor mounts, there also check to see if the dowels in the tranny are in if not it will allow the motor and tranny to move against each other.
Check out dsmtuners.com and dsmsource.com
tofasttoslowforyou is offline   Reply With Quote
Old 11-13-2007, 07:51 AM   #19
Celerity's Avatar
Hey, I have two front and one rear seat for the 1G DSM. All are mint from a 20k miles car . Lemme know if you're interested in that or any other part. (Heads are bad, engine is dirty and the trans is auto)
Old 11-13-2007, 09:02 AM   #20
well i am looking for dsm parts so if any one has em let me know
Old 11-13-2007, 10:15 AM   #21
girly.
Ride:  94 hatch
if you need motor parts, lmk.
Old 11-18-2007, 09:06 PM   #22
Grandpa
88blacksi's Avatar
you do
Old 11-18-2007, 09:06 PM   #23
Grandpa
88blacksi's Avatar
you have jdm cyclone intake
Old 11-18-2007, 09:06 PM   #24
Grandpa
88blacksi's Avatar
with the 2 set of runners
Old 11-18-2007, 09:07 PM   #25
Grandpa
88blacksi's Avatar
oh yeah you have rear vicious AWD tranny
