Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
I can't stop! (wondering about my SS brake lines)
Old 04-10-2007, 01:04 PM   #1
Silverchild79's Avatar
Rep Power: 192 Silverchild79 has a reputation beyond repute
Silverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond repute
Send a message via AIM to Silverchild79 Send a message via MSN to Silverchild79 Send a message via Yahoo to Silverchild79
Default I can't stop! (wondering about my SS brake lines)
so I bout my SS lines, I just got some Stop tech, they're SS hydraulic lines, you can't fuck that up
this is what I bought
StopTech Stainless Steel Brake Lines: buybrakes.com for the front and
StopTech Stainless Steel Brake Lines: buybrakes.com for the rears
the application guide says R32,R33,S14,300ZX-All for the front and 240SX 89-98 for the rears so I HAVE to have ordered the right shit (R33 front calipers and stock rear calipers). So a question for you who've done this
here's the caliper
and here's the front brake line
specifically here's the fitting
how does that mate to the caliper?
now the rear lines (which are much to short to go in the front) came with a fluid bolt and line
which look like a much better fit but after examining the OEM lines these are way to short to be the fronts.
can someone enlighten me? I would think after 6 years of working with these lines on aircraft there would be no curve balls left...
Did I just say something interesting or funny? Check out my blog for more...
http://campassmore.wordpress.com/
Silverchild79 is offline   Reply With Quote
Old 04-10-2007, 02:59 PM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
cant view the pics from here at work
i will take another look when i get home and get back to you
МОΛΏΝ ΛΑΒΈ
Old 04-10-2007, 03:44 PM   #3
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
they sent me the wrong ones for my bosess tl. too and the fitting broke and they would not pay for the fix the just sent the right ones after i complained
DONT INSTALL until you talk to matt at stop tech
DONT INSTALL
http://pandora.com/
Old 04-10-2007, 04:37 PM   #4
thank for the doomsday warning formby, who should I say told me to call (IE your name dood)
anyways for anyone trying to help me here's some more pics
The calipers came from Ebay, the seller had great ranking and he said they were R33, they do look slightly different then the 300Z
Here's the back of the caliper, there is a screw in bolt that looks to retian a small metal tube which serves as a line
Here's the front line kit, The "bulkhead fittings" are on either side of the line rather then just one, I'm not exactly sure how that's supposed to adapt to the claiper, and I'm an Aerospace Hydraulic craftsman lol. Those 2ea metal fitting you see in the middle are solid and slide across the surface of the line, I'm guess those with the brass reatining clips hold the line in place?
looking inside the bulkheads on one side the the interior surface is Male/Male on one end
And Male/Female on the other
After a brake line inspection on my stock system the rear line kit looks like a perfect match, length, fittings, everything, although I'm still not sold on using a brass O ring for a fluid seal
So that's as good as I can explain it
Thanks in advance
Old 04-10-2007, 04:44 PM   #5
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
im sure you'll be fine with the o-rings... thats what alot of calipers use. all my hondas and mirages had that same type of fitting on the front calipers. its called a banjo fitting.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 04-10-2007, 05:00 PM   #6
formby's Avatar
tell them a friend was sent the wrong lines with his kit and you want to verify that you have the right ones.... dont give him my name... i never sent the other lines back because he would not fix the broken fitting.
but he did take his time and helped me to the fullest of his ability.
http://pandora.com/
Old 04-10-2007, 07:11 PM   #7
Sometimes it's no fun figuring stuff out
the guy who sold me the calipers forgot to include the assembly I would need to connect the lines too
yup it's the right lines
see the attached
fuck
Old 04-10-2007, 07:28 PM   #8
ScrapinSi's Avatar
Rep Power: 48 ScrapinSi will become famous soon enoughScrapinSi will become famous soon enough
I was just gonna say it looks like the seller cut the brake lines instead of unscrewing it, as that is a hard line, and there is no reason to replace it with a braided line...
Time to go line shopping...
this country is turning into a bunch of fucking pussies... if this keeps up, pretty soon we'll be singing the french national anthem. -E_SolSi
ScrapinSi is offline   Reply With Quote
Old 04-10-2007, 08:03 PM   #9
I called an importer on the east coast, I'll here more tomorrow
Old 04-10-2007, 08:43 PM   #10
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 263 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
DONE.
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
klyph is offline   Reply With Quote
Old 04-10-2007, 10:09 PM   #11
ScrapinSi's Avatar
Dont forget the JB Weld too...
Old 04-11-2007, 01:06 PM   #12
E_SolSi's Avatar
you can go to most auto parts stores and get the hard lines with the fittings etc...
might need to cut and re-flare them to get the proper length etc but its easy enough
that would be my suggestion
just bring a brake line and a caliper with you to verify the right fitting sizes
МОΛΏΝ ΛΑΒΈ
Old 04-12-2007, 06:00 PM   #13
between buybrakes.com and stop tech I learned some stuff
1. Those front lines are mis made, the second ends fittings shouldn't me opposite like they are
2. The stainless lines they make for their aftermarket calipers should be a perfect fit for my car and the R33 GTS calipers, without the steel lines
the guy at buybrakes.com has been super helpful, I'll keep you posted
Old 04-17-2007, 02:30 PM   #14
UPDATE
The guys from buybrakes.com forwarded the pictures to stop-tech to confirm the lines were incorrectly assembled. Once they got the confirmation they arranged the return.
Now the correct lines are being shipped to me with a return postage included, they charged my card $7 for the difference in price between the kits. And it's taken care of
Larry & Dave at buybrakes.com really took care of this for me. All I had to do was say I was unhappy and they made it right, research and all. I can't say enough good shit about the experience
Next stop, Brembo Rotors and rebuilding the calipers :-)
Old 04-18-2007, 10:28 AM   #15
E_SolSi's Avatar
МОΛΏΝ ΛΑΒΈ
Old 04-18-2007, 10:35 AM   #16
formby's Avatar
clears throat
stop-tech doesn't know anything about brake lines it seems.... they always send the wrong lines
http://pandora.com/
Brake rotor/caliper upgrade Andrew HYBRID -> ED-EF / DA 7 03-03-2006 08:58 AM
Stainless Steel Braided Lines NoJokE General Tech and Maintenance 3 05-14-2003 05:26 PM
Ss Brake Lines For 92 Accord luVTEC Wheels / Suspension / Tires / Brakes 2 04-01-2003 04:21 PM
93 Cx A/c Removal & Fuel / Other Lines. Engine Rem Hybrid93Hatch HYBRID -> EG-EK / DC 1 03-05-2003 11:07 AM
Aem Rear Disk Brake Conv Canuck 93 Civic Si Wheels / Suspension / Tires / Brakes 0 01-30-2003 05:38 PM
