HS Troll...And Mod
Ride: 2001 Honda S2000
ive only done a timing belt 2 ways on a honda.
a) use the timing belt tool (you can get it from honda or snap on, but both are WAY too expensive). b) use an impact and pray. usually b takes some time cause that nut never wants to come off, and then when it finally does come off.....how are you going to get it back to the right torque.......thats the question that has plagued back yard honda freaks for years. my advice is go to the dealership and buy the tool if you want it done right (i even broke down and did it).
If you PM me with tech questions, you better have a link to the thread in your PM. Need engine Components? -- Call Us. Tell them Fritts sent you and they will cut you a deal you will have to hear to believe. |
#3 | |
I made the millionth post
Ride: 03 350z, 03 CL-S, 02 Excursion, 91 CRX Si, 86 CRX Si
theres also a hole in the tranny where you can see the flywheel...have someone bind it up with a prybar and hit the crank bolt with a big fuckin pipe on your breaker bar (last resort) go easy or you'll snap the bolt (fucked) -heat it up if you can
Hold it fellas. I'm afraid you're just too darn loud. Next please. BRING THE NEXT GROUP PLEASE. |
Cogito Ergo Sum Steampunk
Impact is the only way. You use pry bars and you'll break the pulley more than you'll get that bolt out.
#6 |
That's complete shit man.
#7 | |
!!YTINASNI
No way in hell I'd try the "rope" trick.
Impact ftw.
#8 | |
Dismember
My Project 1978 Honda Civic D16A1 swap - IT IS ALIVE! Do not PM me with tech questions. I will NOT know the answer. |
#9 |
put a breaker bar with the socket on the crank bolt and position the bar so it is to the left of the pulley and resting on the ground
then, try to start the car
#10 | |
Chicks dig the box
Ride: 2006 Scion xB
i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i! i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i! i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i http://www.hondashowoff.com/profile.php?id=3331 <-- my former SI This is blue |
#11 |
TheManRSW
Ride: 1995 Honda Del sol Si
Turning the car over with a breaking bar on it will not work with Hondas...it will actually tighten the bolt or break it (works on chevys though). Your best bet is to use the tool from Honda or snap-on...that's why they make them.
