Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
KA24DE Turbo Size question
Old 06-19-2005, 03:03 AM   #1
Silverchild79's Avatar
Rep Power: 192 Silverchild79 has a reputation beyond repute
Silverchild79 has a reputation beyond reputeSilverchild79 has a reputation beyond repute
Send a message via AIM to Silverchild79 Send a message via MSN to Silverchild79 Send a message via Yahoo to Silverchild79
Well I was doing some research on turboing the old KA over at boostdesigns.com they have a great selection of aftermarket support BTW if you own a 240SX. But it left me wondering. There setups (the ones they sell) use a T3/T4 hybrid, they claim them to best they best choice powerbandwise. But considering some people use T04's on B series engines, a T04 sounds like a better selection for a KA24 doesn't it? If anyone has some knowlege on this I would appriciate it. The T3/4 just sounds kinda small...
Did I just say something interesting or funny? Check out my blog for more...
http://campassmore.wordpress.com/
Silverchild79 is offline   Reply With Quote
Old 06-19-2005, 04:19 AM   #2
Picture of Retarded Cat
Battle Pope's Avatar
Ride:  2007 Civic LX
Rep Power: 172 Battle Pope has a reputation beyond repute
Battle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond repute
I think they probably recommend using the hybrid because 1: it will put out less boost to start with (you might not be building the engine), 2: less lag, and 3: mildly cheaper unit.
The main problem with the KA is the nasty ass head and less desireable internals, but you probably knew that.
There used to be a site that specialized in KA-turbo builds and they had a very informative outline of all the things that should be done and what order you should do them in. They also sold parts. Unfortunately I can't remember the site.
Originally Posted by Jeremy Clarkson
A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Battle Pope is offline   Reply With Quote
Old 06-19-2005, 10:38 AM   #3
Rep Power: 24 nismogod is off the scale
Send a message via AIM to nismogod
you can pick up a ton of power by porting the head.
but i think either of the turbos on the site should be just fine for a mild build. or even for a medium build it you go with the bigger one.
Power is nothing without Control.
nismogod is offline   Reply With Quote
Old 06-19-2005, 01:38 PM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
http://www.ka-t.org
Quite a few T3/T4 setups work really well on the KA24- you have to realize that the turbo Honda guys are going to 9000rpm most of the time, and the KA will take you to 7000rpm tops (unless you build the head). The boost curve looks totally different with the larger engine but lower revs. Start reading compressor maps and you'll see what I mean. The T4 compressor section will still give you all the big boost that a straight T4 turbo would give, but the T3 turbine will make you spool faster. It's a good combo for a budget turbo setup- that or you could go balls out and get something like a GT35R.
Old 06-19-2005, 06:01 PM   #5
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
gt28rs. all day. perfect match.
Old 06-19-2005, 11:51 PM   #6
Rep Power: 17 Dman1100 is off the scale
Send a message via AIM to Dman1100
you buying?
Dman1100 is offline   Reply With Quote
Old 06-20-2005, 12:04 AM   #7
Rep Power: 38 NissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to all
NO! Brian... its WAAAY TO SMALL to be good... fucking disco bitches....
t66 that bitch...
NissanNiNjA2nd is offline   Reply With Quote
Old 06-20-2005, 12:45 AM   #8
Calesta's Avatar
Ride:  2003 S2000
Originally posted by NissanNiNjA2nd+Jun 19 2005, 10:04 PM--><div class='quotetop'>QUOTE(NissanNiNjA2 nd @ Jun 19 2005, 10:04 PM)</div><div class='quotemain'><!--QuoteBegin-pissedoffsol@Jun 19 2005, 05:01 PM
t66 that bitch...
[/b][/quote]
Way too small. The T66 would be a bit large for me though.
Old 06-20-2005, 09:45 AM   #9
RETIRED
too small?
come on.
the VE of the ka is damn close to the VE of the 1.8 miata motor, which the disco was designed for. ka's won't rev out... and the .80 a/r is plenty.
Old 06-20-2005, 08:40 PM   #10
Calesta's Avatar
Ride:  2003 S2000
No way man. I'd swap the cams and then run the bigger turbo.
Old 06-20-2005, 10:47 PM   #11
RETIRED
if you think so...
i mean, think about it... sr's come with a t25 with a smaller A/R
add a little displacement, and about the same VE (when turbo'ed at least)
and the 28rs is a perfect match IMO
Old 06-20-2005, 11:37 PM   #12
Calesta's Avatar
Ride:  2003 S2000
Yeah, but the T25 still runs out of steam pretty quickly on an SR, not to mention a KA. The 28RS matched up to the flow rates of the KA block even calculating at 80% VE is still too small.
