Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
mmm new mirage sextoys.
Old 04-16-2008, 11:30 AM   #1
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
Default mmm new mirage sextoys.
got the RL coils finally xD
here we go.
comparison against the old blown toser from front passenger side.
replaced front passenger evo4 strut and mickeymoused coilover setup
almost blown front driver TOSER coilover and RL coilover
fapfuckingtastic!
mmm pillows again
now for those who dont know how to install these, here is a quickie.
loosen tire lugnuts a bit, jack up car, and remove tire. open hood, and loosen three triangular 14mm strut top nuts.
go to the strut shaft and loosen/remove the two 17mm nuts/bolts that hold the strut to the knuckle. if your strut has the option, also remove the C clip holding the brake line to the strut using a screwdriver. fully loosen strut top 14mm bolts.
reinstallation is the reverse of removal.
i start by putting the strut in place and nearly fully tightening the 14mm top bolts. then i use a jack and raise the knuckle up to meet the shock, and secure the 17mm nuts and bolts. after that i would install the C clip for the brake line, and put the wheel back on and lower the car. tighten the top 14mm nuts. tighten the wheel. done.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 04-16-2008, 01:00 PM   #2
..is grounded.
dacheat's Avatar
Ride:  '84 buick (rusted)
Rep Power: 268 dacheat has a reputation beyond reputedacheat has a reputation beyond repute
dacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond repute
good thread!
marco....
dacheat is offline   Reply With Quote
Old 04-16-2008, 01:38 PM   #3
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
Those look nice! Good work!
PSN Network ID: BrutalB83
Old 04-16-2008, 02:29 PM   #4
|Chaz|'s Avatar
Ride:  92' EG Sedan
Rep Power: 157 |Chaz| has a reputation beyond repute
|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute
Send a message via AIM to |Chaz| Send a message via MSN to |Chaz| Send a message via Yahoo to |Chaz|
Sexy (gotta continue the pattern)
XBL Gamertag = i1Chad1i
i (space here)Chaz(space here)i
|Chaz| is offline   Reply With Quote
Old 04-16-2008, 02:52 PM   #5
cost? $900 for the front and rear set. $1500 MSRP new. they have ~6K miles on them.
36-way adjustable. adjust through an easy to turn, clicking knob on top of each strut/shock. the fit and finish of these babies is so much nicer than the TOSERs.
Old 04-16-2008, 02:59 PM   #6
|Chaz|'s Avatar
Ride:  92' EG Sedan
Sounds like you got a pretty sweet deal. Just curious, but how often do you find yourself adjusting them? Do you use it mainly for when you track it or autoX it?
Old 04-16-2008, 03:23 PM   #7
full soft for daily, and 24 clicks up front/ 36 rear for autox.
Old 04-16-2008, 03:23 PM   #8
this car gets over 5K miles a month.
Old 04-16-2008, 03:45 PM   #9
|Chaz|'s Avatar
Ride:  92' EG Sedan
Holy crap dude, where all do you drive?
Old 04-16-2008, 04:04 PM   #10
80 mile round trip per day to/from work, usually a few hundred on the weekends.
and for its 3rd year in a row it will be a bi-weekly track whore
Old 04-16-2008, 05:31 PM   #11
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
I put almost 30k on my shitvic, I got it in October I think.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 04-16-2008, 06:12 PM   #12
word dude. there are those of us who "own" and those of us who "drive"
Old 04-16-2008, 06:23 PM   #13
The Trisexual
3k miles has probably been the minimum I put on my cars in a month in the past 3 years.
Current Rides
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
Old 04-17-2008, 12:35 AM   #14
Rep Power: 14 91_civic_si has a spectacular aura about91_civic_si has a spectacular aura about
Makes me wish I still had my Mirage.
91_civic_si is offline   Reply With Quote
Old 04-17-2008, 02:59 AM   #15
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 189 awptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
You can always tell someone who drives by the way they talk about their car. Owners are funny people to listen to.
I think I've put about 35k miles on this car since I bought it back in May. But damn dude. 5k a month? That's quite a bit of driving. I used to put about 2k/week when I had a job that entailed driving all over hell and creation all day. That was actually pretty fun for the first month or so.
4 to 5 hours a day in the car driving is nothing to sneeze at though.
Nice suspension.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 04-17-2008, 05:48 PM   #16
Cogito Ergo Sum Steampunk
Celerity's Avatar
Ride:  1972 Plymouth Satellite, 1988 Jeep Wrangler
Rep Power: 347 Celerity has a reputation beyond repute
Celerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond repute
Send a message via AIM to Celerity Send a message via MSN to Celerity myspace
And there are those of us who drive "well" and then there is "you".
Word dude !
Originally Posted by SlushboxTeggy View Post
Cel is the biggest pussy and the biggest bad ass at the same time. He is enlightened and not . He can go after someones mind with scalpel like precision or smash their head in with a rock tied on a stick. The best way to describe him... He is an enigma.
Check out my new Steampunk experiment: http://www.pandora.com/people/steven.earl#
Celerity is offline   Reply With Quote
Old 04-17-2008, 05:49 PM   #17
Celerity's Avatar
36 way adjustable too... Who the hell needs that ? That's like Sigma 12 precision tuning. Pressure variances in the ambient air make that kind of difference on a strut.
Old 04-17-2008, 05:57 PM   #18
since i drive better than well i'll take that as a compliment xD
the day you beat me on the course is the day i hand you the keys to the mirage steve
i dont get 36 way adjustable either 8 or 12 or 16, but yes 32 is extreme.
Old 04-17-2008, 07:53 PM   #19
Celerity's Avatar
It may be a while before I can stand and deliver to an autocross. What may be interesting is if you and I can borrow Clayton's Gazelle . Gives us a chance to start on a blank slate and see who adapts first.
Old 04-25-2008, 08:59 AM   #20
if clayton ever gets up early enough to make it to autox with it, yeah you're on!
ultra rare rear window visor!
Old 04-25-2008, 09:04 AM   #21
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 227 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
I dont really like the wing but the window visor is pretty bitchin'.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
efhondakid is online now   Reply With Quote
Old 04-25-2008, 09:41 AM   #22
the wing is real deal authentic Evo5
btw i'm the only one in the US with that visor.
Old 04-25-2008, 09:42 AM   #23
The Trisexual
If you paint the wing, I might like it. But on the visor.
I need to find a front visor for the GC.
Current Rides
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
Old 04-25-2008, 10:35 AM   #24
My name is Byron.
efhondakid's Avatar
"Im so JDM I sleep on the right side of the bed" I didnt even see it wasnt painted until 92civic said that, prob look a lot better when its painted.
^ (dont listen)
Old 04-25-2008, 10:49 AM   #25
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
lol..i asked him awhile back why its not painted,,the car looks sick(even with the bodykit)
and how are you the only one in us with the visor???
is it custom made or just not available here???
anyway props on the car.
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
mirage brake upgrade :) TurboMirage Other Vehicle Discussions 81 03-30-2008 11:48 PM
evo lancer evo intercooler pipes eclipse civic mirage RSS-Bot Auctions 0 12-14-2007 07:53 PM
exciting things happening with my mirage board :) TurboMirage Members' Lounge 1 01-26-2007 12:59 AM
sooooo the 2000 Mirage from Hosmer. TurboMirage Auto Multi-Media 36 07-23-2006 02:24 AM
a turning point for the miracle mirage TurboMirage Members' Lounge 30 08-16-2005 12:31 AM
