#26 |
Brutal Moderator
Ride: 97 Integra LS Coupe
Nice! JDM bling FTW!
![]() __________________
#27 |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
the visor was not offered as an option on the US coupe/sedan. its AUDM.
eventually the spoiler will be painted. its on the list............................... maybe when i get a c/f evo replica trunk. __________________
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
#28 |
intercooler mounted so i can start mounting fogs. bumper isnt bolted on yet, so it looks like ass.
![]() ![]() ![]() __________________
#29 |
Brutal Moderator
You can barely tell there's an inter-cooler there. Is that what you're going for?
#30 |
yep.
#31 |
you get the BRAKE
Ultra Ricey rear wing... sorry, just my opinion.
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#32 |
you gotta have the downforce though. its OEM, you know, like your stock civic.
#33 |
you get the BRAKE
There is nothing stock about my civic.
#34 |
i know. hence the joke.
#35 |
you get the BRAKE
Har har. ;l
#36 |
My Vtec is biger then urs
I would cut 2" off that exhaust and weld it back up, also the rear wing is only doable if you make that I/C stand out. At least if your intercooler could be seen, it would add a little respect back to the car, that rear wing with sleeper style interocoler FTMFL
#37 |
going to toss the fujitsubo on soon.
new headlamps... ![]() __________________
#38 |
Ride: 2007 Scion TC, 2005 Suzuki GSX-R 600
Headlights look great. Same with the 500 series. Car looks like its coming together nicely.
Since you have projectors now, you might wanna look into HID's now. __________________
When this is all over I think we should get an apartment together. |
#39 |
nah the 55w ones are much brighter than silverstars.
got 17s... ![]() __________________
#41 |
two of the kooks mounted today
#43 |
i had the enkeis...
i paid $100 for the four hankook ventus. they have like 50 laps on them at the track. they are only half dead perfect for me. i'll get the rest of this season and next out of them.__________________
#44 |
sooooo out with the old tranny with bad bearings and in with a much lower mileage one from evoIT. replaced the axle seals. works great!
put on the split intake manifold too. much easier working the intake and coolant ports seperately. much much easier. pulled the ACT2600 clutch and disc off of my old mirage's 2nd popped 1.5L motor since froggie decided he wasnt going to use it. he's a pussy and prefers the stock plate. the disc was toast but mine was still mint after 50K hard miles. popped the plate on and its so nice. (mad props to DIYMIRAGE for the replacement low mileage clutch and pressure plate i installed 50K miles ago i totally torqued everything down with an impact gun this time. usually i just breaker bar all the big bolts, but i decided to since i had one at my disposal. front end feels much more solid. kenny and i welded the busted to shit RRM mount up, and my trans mount solid. next in a few days i'll do the timing belt mount. results: shifts like butter. i really missed the hard actuation of the ACT clutch. i'll have much better launches now, especially with the 225 wide slicks. throttle response is better, since i had some sort of weird hesitation/jerking due to the busted poly mount. still gotta work on the TPS, its not completely correct (or the BISS?) i broke the transistor/resistor that sits on the distributor. anyone know where i can get a replacement for that? i may hit up the junkyard at some point next weekend if i have time. the little one wire cylinder looking thingie. i think i may need to replace the thermostat, or there isnt enough coolant in the system yet. i pegged H for a few miles before i realized it, and as soon as i turned on the heat it went back to normal. __________________
#46 |
no shit, im not going to impact components like that. i have a digital torque wrench
#47 |
light blue metallic rs5's wrapped with 225/45r15 hankook ventus slicks.
quick question, how do i get the rest of the paint off the tires? i was thinking 1000grit wetsandpaper. ![]() __________________
#49 |
Chopped N' Screwed.
Ride: SE-R Spec V
Chris, we need to make the mirage all one color again. You're comming over, and we're spray bombing the entire car, including the engine bay flat black. You have no choice.
J/k, but seriously you need to paint the engine bay and front crossmember. Those slicks look nasty. ![]() |
#50 |
flat black sounds good. but its still so shiny!
i'll paint the bay when the engine comes out. most likely flat black. __________________
| mirage brake upgrade :) | TurboMirage | Other Vehicle Discussions | 81 | 03-30-2008 11:48 PM |
| evo lancer evo intercooler pipes eclipse civic mirage | RSS-Bot | Auctions | 0 | 12-14-2007 07:53 PM |
| exciting things happening with my mirage board :) | TurboMirage | Members' Lounge | 1 | 01-26-2007 12:59 AM |
| sooooo the 2000 Mirage from Hosmer. | TurboMirage | Auto Multi-Media | 36 | 07-23-2006 02:24 AM |
| a turning point for the miracle mirage | TurboMirage | Members' Lounge | 30 | 08-16-2005 12:31 AM |
