Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
mmm new mirage sextoys.
Old 07-07-2008, 11:45 PM   #76
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 219 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
racing logic rear full coilovers installed. i no longer have rear passenger suspension droop and the ride height has equaled out.
destroyed tosers that came out. thank god those are finally gone.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the Little EVO5
Old 07-09-2008, 10:01 PM   #77
all wired in. started on the first try. no codes.
Old 07-09-2008, 11:26 PM   #78
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 122 klyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
You should wire an Apexi AFC in there just for good measure.
My Project
1978 Honda Civic D16A1 swap - IT IS ALIVE!
Do not PM me with tech questions. I will NOT know the answer.
Originally Posted by formby View Post
I've come to the conclusion that a family is the one you make not the one your born into.
klyph is offline   Reply With Quote
Old 07-09-2008, 11:56 PM   #79
i HAD one in there. it didnt work. the RPM readings were all off due to the car alarm/starter.
Old 07-10-2008, 12:01 AM   #80
Dismember
How in the hell would a car alarm affect the RPM signal?
My Project
Old 07-10-2008, 08:39 AM   #81
the starter portion of the alarm stores the RPM value so if the car is started with the remote, and is rev'd over a certain RPM it shuts the car off.
Old 07-10-2008, 10:58 PM   #82
okay, buttoned up and put away.
re-taped everything and double checked my soldering. everything was still good. tossing no codes.
hooray for success! tomorrow ima flash it to 1.49 see if i can get the LC1 back.
Old 07-18-2008, 08:21 PM   #83
well the tach and emanage are now working 100%. had issues with the RPM wire. hooked both to the CPS and voila!
fresh wash and wax
Old 07-18-2008, 08:34 PM   #84
learning in progress
formby's Avatar
Rep Power: 91 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
looks great. last night on pinks there was a mirage with a awd eclipse swap. made me think of your car.
http://pandora.com/
Old 07-19-2008, 01:56 AM   #85
yeah i have that episode saved
soon! maybe sooner than you think.
Old 07-21-2008, 08:10 PM   #86
from the HONE meet. washed/waxed and every reachable surface in the engine bay armor-alled.
Old 07-21-2008, 08:48 PM   #87
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 101 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Looks good.
Looking for a P28 and B-series turbo parts, PM me.
Old 07-21-2008, 08:50 PM   #88
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 68 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
As Paris Hilton would say, that's hot!
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406
Originally Posted by Blanco View Post
Headers and a turbo, eh? Brilliant advice, Doctor. Simply brilliant.
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 07-27-2008, 11:40 PM   #89
today from hot-o-cross LOL
Old 08-01-2008, 11:02 AM   #90
first ever set of 1.5 intake and exhaust manifold flanges. now i can make an equal length turbo manifold and a SMIM.
fap fap fap fap
Old 08-02-2008, 03:18 PM   #91
started on my new swaybar bracketry.
going to make brackets off the frame rail using 2x2 square tube. probably overkill since im welding to the frame but oh well. after working out some measurements with a ruler, i've found im going to make the brackets 9.5 inches long and add on an extra inch outward toward the bar to fill the gap. i have some things i have to move a bit first though, and the new headerback (catless) will go on next week so i can finish the drivers side bracket.
the plan:
once the brackets are up and welded into place im going to weld the grade 8 nuts to the inside of the square tube. hooray!
started making the little brackets.
LOVE having a drill press.
bolted up.
tacked things down a bit.
Old 08-02-2008, 04:17 PM   #92
these too
Old 08-02-2008, 04:25 PM   #93
HS RA
eg6sir's Avatar
Ride:  Le Car
Rep Power: 225 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
