Ride: 1998 Eclipse GSX
Well, injectors are on and fuel management is working fine. However, I've ALREADY maxed this turbo, and only at 28 lbs/min of airflow too instead of the ~35 I was hoping for. For the record this is on a 95 GSX with a big T28. Sure I should be satisfied though, with that kind of airflow I'm making a good 250-280 awhp based on other logs I've seen of AWD DSMs...
But when are we ever satisfied? It's time for a bigger turbo 300 awhp or bust [img]style_emoticons/<#EMO_DIR#>/ph34r.gif[/img] |
#3 | |
!!YTINASNI
<div class='quotetop'>QUOTE(silver @ Nov 21 2005, 12:23 PM) Quoted post</div><div class='quotemain'>
Well, injectors are on and fuel management is working fine. However, I've ALREADY maxed this turbo, and only at 28 lbs/min of airflow too instead of the ~35 I was hoping for. For the record this is on a 95 GSX with a big T28. Sure I should be satisfied though, with that kind of airflow I'm making a good 250-280 awhp based on other logs I've seen of AWD DSMs... But when are we ever satisfied? It's time for a bigger turbo 300 awhp or bust [img]style_emoticons/<#EMO_DIR#>/ph34r.gif[/img] [/b][/quote] I hope this isn't a daily driver.. 35 psi?? RRRRRROoooooooooommmmmmmOOOOOOOAAAA AAA BANG!
RETIRED
why would you want an 18g??? he'd have to get a whole new manifold and everything....
bolt it on y0 http://store.yahoo.com/cheapturbo/gt2871r.html |
#6 |
RETIRED
<div class='quotetop'>QUOTE(phyregod @ Nov 21 2005, 11:48 AM) Quoted post</div><div class='quotemain'>
<div class='quotetop'>QUOTE(silver @ Nov 21 2005, 12:23 PM) Quoted post</div><div class='quotemain'> only at 28 lbs/min of airflow too instead of the ~35 I was hoping for. [/b][/quote] I hope this isn't a daily driver.. 35 psi?? RRRRRROoooooooooommmmmmmOOOOOOOAAAA AAA BANG! [/b][/quote] lbs/min is NOT psi. cfm is volume. psi is pressure. apples and oranges and we aren't making juice |
#7 |
JDMASF%#K
Ride: Civic
<div class='quotetop'>QUOTE(pissedoffsol @ Nov 21 2005, 02:27 PM) Quoted post</div><div class='quotemain'>
<div class='quotetop'>QUOTE(phyregod @ Nov 21 2005, 11:48 AM) Quoted post</div><div class='quotemain'> <div class='quotetop'>QUOTE(silver @ Nov 21 2005, 12:23 PM) Quoted post</div><div class='quotemain'> only at 28 lbs/min of airflow too instead of the ~35 I was hoping for. [/b][/quote] I hope this isn't a daily driver.. 35 psi?? RRRRRROoooooooooommmmmmmOOOOOOOAAAA AAA BANG! [/b][/quote] lbs/min is NOT psi. cfm is volume. psi is pressure. apples and oranges and we aren't making juice [/b][/quote] Fucking hilarious. Quite possibly info-worthy. |
#8 |
<div class='quotetop'>QUOTE(pissedoffsol @ Nov 21 2005, 01:27 PM) Quoted post</div><div class='quotemain'>
<div class='quotetop'>QUOTE(phyregod @ Nov 21 2005, 11:48 AM) Quoted post</div><div class='quotemain'> <div class='quotetop'>QUOTE(silver @ Nov 21 2005, 12:23 PM) Quoted post</div><div class='quotemain'> only at 28 lbs/min of airflow too instead of the ~35 I was hoping for. [/b][/quote] I hope this isn't a daily driver.. 35 psi?? RRRRRROoooooooooommmmmmmOOOOOOOAAAA AAA BANG! [/b][/quote] lbs/min is NOT psi. cfm is volume. psi is pressure. apples and oranges and we aren't making juice [/b][/quote] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] good stuff 18g doesn't need another manifold, but more power can be made from the evo 3 16g's that are so popular now. I have about 1200 to blow maybe, looking towards a 50 trim variant and some cams, that should be good for 50% more airflow easily eh. 370+ awhp or bust now [img]style_emoticons/<#EMO_DIR#>/ph34r.gif[/img] |
#10 |
The key is that they're both mitsu flanged. 18g's will most likely use the TD05H turbine housing, which definitely bolts on to a 2g manifold. You may have heard that 16g/18g/20g/25g's don't bolt on to the 2g's in general, but that's due to the turbos firing upward and the difference in oil feed configurations.
#11 |
<div class='quotetop'>QUOTE(pissedoffsol @ Nov 21 2005, 05:05 PM) Quoted post</div><div class='quotemain'>
how does a mistu flanged 18g fit a t25 flanged mani??? [/b][/quote] cuz mitsu turbos have the same bolt holes that the T-2 series do. and for some reasons I dont see you maxing out the t25 at 35psi and only making 300whp... |
#12 |
<div class='quotetop'>QUOTE(NissanNiNjA2 nd @ Nov 21 2005, 04:20 PM) Quoted post</div><div class='quotemain'>
cuz mitsu turbos have the same bolt holes that the T-2 series do. and for some reasons I dont see you maxing out the t25 at 35psi and only making 300whp... [/b][/quote] Once again, it's not a t25, I'm not running 35 psi of boost, and I'm not making 300 awhp. |
#14 |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
this thread is full of various amounts of ownage.
stick with your subarus, nissans, and hondas kids [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] |
#15 |
learning in progress
Ride: 00' Montero sport, 99' lsv civic
why dont you buy a holset.....
and this http://www.bullseye-power.com/product_info...&products_id=56
#16 |
Cogito Ergo Sum Steampunk
<div class='quotetop'>QUOTE(TurboMirage @ Nov 22 2005, 09:45 AM) Quoted post</div><div class='quotemain'>
this thread is full of various amounts of ownage. stick with your subarus, nissans, and hondas kids [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] [/b][/quote] Oh god no. Also, regardless of the whole "I have torque" argument, and the fact that this is a Honda forum, I have this to say: Honda Rocks out on the collective faces of Subaru, Nissan, Toyota and just about anything else. Don't believe me? Motor Trend does [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
#17 |
no no nothing to do with that. it was more of a general mitsu knowledge ownage.
but this IS a honda forum, so... you know. |
#18 |
HS Troll...And Mod
Ride: 2001 Honda S2000
thats why i generally avoid posting here. if it aint a chevy small block (or in some occasions a big block)....i stick to honda.
If you PM me with tech questions, you better have a link to the thread in your PM. Need engine Components? -- Call Us. Tell them Fritts sent you and they will cut you a deal you will have to hear to believe. |
#19 |
<shakes head in disbelief>
Morons. <face in hands>
- Jody - 2004 Colorado ZQ8 - I5, M5, Regular cab - 209.9whp/210.7wtq 1986 Mustang GT - V8, M5 - 213.0whp/279.2wtq |
#20 |
Holset is beyond what I want right now, and will cost more to me in the end through needing the turbine housing, turbo itself, external, redo my exhaust etc. I had been looking at T04E 50 trim hybrid turbos but eventually decided on an Evo III 16g.
OEM quality and has been recorded to flow upwards of 44 lbs/min propelling full weight 2g AWD's into the 11.5-11.8 range [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] More updates as I get shit in. Sucks realizing you just dropped a grand into your car (yes yes you've all spent more, but I'm in college and now broke, again). |
#21 |
Well, I've bought the turbo for a grand total of 602.85 after shipping, and everything I need for a FMIC setup for 329.83 after shipping.
After selling parts I'm recovering about 675, so net spent: 257.68 I'll be busy this winter, and we'll see what kind of airflow I get with this sucker. Then to the track come..march/april? |
