Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
Ranger overheating...Sport Trac cluster at fault????
Old 03-21-2007, 06:23 PM   #1
...PENDEJO....
BodyDroppedNikes's Avatar
Ride:  bagged Ford Ranger Splash
Rep Power: 202 BodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond repute
BodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond repute
Send a message via AIM to BodyDroppedNikes Send a message via Yahoo to BodyDroppedNikes myspace
Default Ranger overheating...Sport Trac cluster at fault????
i recently installed a set of gauges out of a 2002 Explorer Sport Trac in my 1995 Ford Ranger Splash with the 3.0L v6. after i installed the gauges, the temperature needle goes to the HOT and when i cut the truck off it stays in same position where i cut the truck off (it wont drop down to COLD like normal). when i installed the gauges , the needle was buried in the hot position i noticed. starting the truck when the truck is cold (ie hasnt been running for awhile), the needle will go from where the reading it was last at, drop down to the normal range and then as im driving it will go to HOT and the CHECK GAGE lights pops on. none of this happened when i had the stock gauges in the truck. ive added oil, checked the antifreeze and the gas as recommended in the owners manual in my truck and all is fine. could the Sport Trac cluster be setup different? im not sure what engine the Sport Trac had that the cluster came from. should i put the stock gauges back in because it wasnt doing it before i did the cluster swap?? ive got a 500 mile trip im making in a week with the truck and i need to resolve this issue ASAP. thanks for the help!!
***Please leave this section blank. For office use only.***
-BrianE.
2009 Ford Focus
http://midwestminis.forumotion.com/forum.htm
Originally Posted by MthaFuknGreen
noo... pole like the things strippers are on.
(id say like your mom is on, but i dont wanna get banned.. lol)
BodyDroppedNikes is offline   Reply With Quote
Old 03-21-2007, 07:05 PM   #2
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
I'd put the stock gauges back in and see if the temp gauge does the same thing...more than likely the new cluster is fuct.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 03-21-2007, 07:10 PM   #3
*princess*
Black Widow g2's Avatar
Ride:  90 Integra B16 turbo, 00 Civic Si B18C n/a, 07 Fit Sport
Rep Power: 71 Black Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud of
Send a message via ICQ to Black Widow g2 Send a message via AIM to Black Widow g2 Send a message via MSN to Black Widow g2 Send a message via Yahoo to Black Widow g2 myspace
cluster fucked. lol
i'd say that's the problem... check coolant, does the fan come on? is the relay hooked up right? is that gauge connected properly?
~ArtieTuned - EFI University Certified Tuner~
*ECU Chipping*Custom Programs*Street/Dyno Tuning*
Crome Pro*Motec*Haltech*Autronic*Hondata* Uberdata*Neptune*Fast*AEM* MegaSquirt*and more
In the NorCal area
http://www.artietuned.com
e-mail: tuner@sonic.net or PM me
Black Widow's Baby Pool
Black Widow g2 is offline   Reply With Quote
Old 03-21-2007, 07:12 PM   #4
...PENDEJO....
yeah. i just found out that the temp. sender in the gauge cluster is different because the Sport Trac has the 4.0L in where as my truck has a 3.0L in it. maybe i can just swap out the faces??
-BrianE.
2009 Ford Focus
Old 03-21-2007, 07:16 PM   #5
*princess*
better idea.
In the NorCal area
99-00 civic Si cluster swap into EF How To (pics0) B18C5James HYBRID -> ED-EF / DA 30 07-11-2007 06:25 PM
99-00 SI cluster into an EG adnoh Body / Exterior / Interior / Cosmetics 10 01-28-2006 04:22 PM
OMFG E_SolSi Other Vehicle Discussions 37 11-05-2005 08:14 PM
HAY WHERES LOCO HONKY??? YELLOW HONDAS R KEWL Members' Lounge 96 12-21-2004 04:58 PM
