This is a discussion on s13 tach not working in the Other Vehicle Discussions forum
I'm buying a 92 240sx w/ sr20det done, and the tach does not work, any ideas of why it may not work? The seller says it worked previous to swap.
Any suggestions?...
| | #1 |
| I'm buying a 92 240sx w/ sr20det done, and the tach does not work, any ideas of why it may not work? The seller says it worked previous to swap. Any suggestions? |
| | #2 |
| do they have a vss? |
| | #3 |
| idk much about them, that's why im trying to learn, anybody know a good nissan site? Also isnt the vss for the speedo and not the tach? |
| | #4 |
| cuz the stock tachs dont read the sr20 input. you have to unsoder some connections and then resoder some others I dont remember what off the top of my head. |
| | #5 |
| apparently, you have to do some tachtical soldering. |
| | #6 |
| bad pun...and i dont know why i thought the vss had something to do with the tach. I really do know the dizzy sends that signal... |
| | #7 | |
| Quote:
Is there any way to just swap out the entire cluster for the tach to work? And do you know where I can find some sort of diagram to re-wire it? And would this be re-wiring behind the cluster? | |
| | #8 |
| Start simple - at the signal wire on the dizzyitself. Then do a continuity test through the line to the gauge connector. Finally, check the gauge. The SR20 swap really shouldn't impact the tach unless the physical connection wasn't made. I have an SR20DE in stock form if you need reference. (1993) |
| | #9 |
| I'm more than likely buying an aftermarket tach along w/ boost gauge, autometer cobalt. Backlit LED which isnt bright like the others. So I will need to know which wire on the dizzy is the signal wire for the tachometer |
| | #10 | |
| Quote:
hook the ground clip to the tach wire, hook up the power wires and ground wires up, and use the test light to find the wire that gives you rpm signal to the tach | |
| | #11 | |
| Quote:
The D-PIC gauge in Cobalt is neat though. | |
| | #12 | ||||
| Quote:
that is probably what i will have to do. anyone know what a good nissan - tech site is? Quote:
__________________ DB8 450whp project...... | ||||
| | #13 | |
| Quote:
| | #14 | ||
| Quote:
| | #15 | |||
| Quote:
| | #16 |
| Get a hole saw cut out the entire tach fit in a 4" analog 10k tach wire done. |
| | #17 |
| So, do you know the actual wiring that is needed to get the stock one to work, i dont want to cut out the stock one, also the water temp gauge doesnt work, i was told that the sr20det's don't have a temp sender? Is that correct? |
| | #18 |
| Might Want to ask at Indycarz.com/forums they might know something. Ya never know... |
| | #19 |
| why not try freshalloy or 240sxone? |
| | #20 | |
| Quote:
thanks! that's what I was asking for! | |
