Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
Throttle Position Sensor - Help!
Old 06-21-2007, 08:46 PM   #1
Rep Power: 0 bertaherrington is on a distinguished road
Exclamation Throttle Position Sensor - Help!
My idle sticks between 1000 and 1500 rpm after the car is warmed up (but if i put my foot under the gas pedal and pull up it goes down to normal).
Sooo, I took the throttle body off and cleaned it. Found that the Green vacuum line was completly clogged w/ rust particles so I cleaned it out and the line that it was connected to.
Now I'm trying to check the throttle position sensor but the Hyanes manual is kinda outdated for my 91 LX.
I found a post a while back that Magik8 did where he scanned the shop manual and it listed all the voltages, but it was for a turbo
What I did is put +5 V to the RED wire and Grounded the black wire and measured the voltages between the WHITE (blue in the shop manual) and GROUND. This is what I got..49 4.34
Throttle completely closed: 0.49 V
Throttle completely open: 4.34 V
Can anyone verify these?????? I have to put this back in my car soon so ASAP thanks a lot guys
Built NA Block | Spec Stage 3 hybrid clutch | 440cc RC Injectors | Haltech E6X | JIC FLT-A2 Coilovers | Optima Red Top | 18" KMC Suicide rims on BFG KDW2's | Custom Car Computer | Xenarc 7" VGA screen | DGM Carbon Fiber hood and radio trim | WingsWest 3 piece body kit | PWR Radiator | Sparkco wires | AWR motor mounts | TWM Shifter | Mazda Throttle Position Sensor | Alpine subs, amps, and speakers | Fiberglassed Sub Box | Defi Boost Gauge | AEM WBO2 Gauge |
bertaherrington is offline   Reply With Quote
How to remove a honda Throttle Position Sensor TPS phyregod General Tech and Maintenance 15 06-18-2008 02:18 PM
the new v8 powerplant for the M3 info pissedoffsol Other Vehicle Discussions 19 03-28-2007 05:02 PM
Throttle Position Sensor question hondarin General Tech and Maintenance 4 08-11-2006 10:46 AM
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
Decoding VIN Numbers pissedoffsol General Tech Articles 0 01-11-2004 08:48 PM
