Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
Tranny problem
Old 07-15-2004, 09:01 PM   #1
Ride:  99 Civic
Rep Power: 14 Think is off the scale
Ok, i have a 99 grand am GT, after driving for id say about 20 mins or so, when i go to take off (in first) the tranny seems to be slipping. Such as it will hit about 2.5k rpm and then go into first, same thing as into 2nd as well. Car has about 86k miles on it. Any help would be greatful. thanks
People in glass houses sink ships.
Think is offline   Reply With Quote
Old 07-15-2004, 11:19 PM   #2
Rep Power: 13 ssl2k is off the scale
replace your clutch
nuff said
1991 CRX SI - Built D16Y8 - The piston melter
1990 CRX SI - B18A1 ... ls/vtec in the process y0
1988 Civic DX 4dr - d15b2 w/ mpfi + flaterate t-25 kit
ssl2k is offline   Reply With Quote
Old 07-15-2004, 11:36 PM   #3
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
i think hes got an auto.
get your tranny fluid replaced, or get it filled.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 07-20-2004, 08:22 PM   #4
Ride:  99 Civic
it is auto, and it only seems to be doing it, after i put the car in reverse and then into drive while still rolling a little bit. Not that a big of a deal to stop, but just curious. Thanks
Old 07-20-2004, 08:58 PM   #5
thistownsucks...
hybrid89's Avatar
Rep Power: 33 hybrid89 will become famous soon enough
Send a message via AIM to hybrid89
low transmission fluid.
hole in one of the rubber lines on the transmisiion housing
tarnny is taking a shit!
these are my thoughts....
matt
id rather have a hondata and a stock block
then a sleeved, pistons/rods combo and a hack or fmu
hybrid89 is offline   Reply With Quote
