Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
vg30 dynos
Old 06-15-2004, 06:33 AM   #1
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
does anybody know where i can find some dynos for a naturally aspirated nissan vg30 motor? i want to see if it makes power past 5000rpm.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 06-15-2004, 06:18 PM   #2
Rep Power: 24 nismogod is off the scale
Send a message via AIM to nismogod
built or stock? and in which vehicle?
Power is nothing without Control.
nismogod is offline   Reply With Quote
Old 06-15-2004, 07:48 PM   #3
K2e2vin's Avatar
stock...any car. i raced a saturn in my mom's van, with my bro and cousin in there. neck and neck; i didnt have the gas all the way down. also i was playing around with the gears(1st and 2nd gear), an noticed that it continues to pull past 5000rpm, but i let off close to 5700rpm.
RIP
Old 06-15-2004, 09:30 PM   #4
Dynamometer model: DynaPack
DYNO1: Baseline
Baseline air temp @ 65.6 Degrees Fahrenheit
Peak HP 223.4
Peak TQ 233.7
in a 91 300ZX
dyno
Old 06-15-2004, 09:51 PM   #5
Rep Power: 16 aLLmOtOr is off the scale
Is that from a NA? Its seems kinda high ...
aLLmOtOr is offline   Reply With Quote
Old 06-15-2004, 10:29 PM   #6
ok, i picked 4 random cars with VG30's Naturally Aspirated
all rated in the following categories. remember this is at the flywheel.
Compression Ratio, Valve Train, valves per cylinder, HP @RPM, TQ @RPM.
I would have included Displacement, bore and stroke, Fuel type, and Fuel induction, but they remained the same on each vehicle
1997 Nissan Quest- 9:1 - SOHC - 2 - 151 @ 4800 RPM - 174 @ 4400 RPM
1991 Nissan 300ZX- 10.5:1 - DOHC - 4 - 222 @ 6400 RPM - 198 @ 4800 RPM
1994 Nissan Pickup- 9:1 - SOHC - 2 - 153 @ 4800 RPM - 180 @ 4000 RPM
1994 Nissan Maxima- 9:1 - SOHC - 2 - 160 @ 5200 RPM - 182 @ 2800 RPM
hope this helps
