need help with 5 speed swap wiring
Tein
So much with a little D
I made a 5 speed swap and I belived that the shift wiring is wrong... I am not able to start the car, the starter and battery are new... Do anyone has
A easy dIY or how to do the shifting wiring on a 96 EJ D16Y8... I put on a manual engine harness...
<p>
Was this an Auto before? assuming it is, your proably asking how to make your car think it is in Park. This is the best write up I have found for you</p>
<p><a href="http://www.honda-tech.com/showthread.php?t=1337459" target="_blank">[FAQ] 96-00 Auto to Manual Swap in full detail!! (44pics) - Honda-Tech</a></p>
<p>&nbsp;</p>
<p>its picture intensive, near the bottom of the 1st post is your problem enjoy and good luck
</p>
<p>&nbsp;</p>
I actually follow this link when I made the 5 speed swap in fact I even post this link here before, but I guess I did something wrong so I will check my work again
lol, happens to us all, I did a swap in a Eg 92-95 it was a blast... NOT! anywayz let us know if ya get it if not i look for another atricle for u
I will not be able to work on the car until friday but I will definetly go back and advise
Thanks a lot
