Blakwolf9666
I have 92 civic lx 5speed with the stock D15y7 i believe
Ok i have 2 problems right now the first is the idle, for some reason when i turn the car on the engine surges up and down i thought is was a sensor on the back of the intake manifold because it stopped when i plugged it in (it wasnt plugged in when i got the car) but it started doing it again just yesterday when i turned the car on. The other problem is the throttle seems to stick, when you go to give it gas you need to give it a little force on the pedal as well as the throttle body itself.
any help would be great i need to get the car going for school and work
