98ek hatch b16swap
jay252
I got a idle issue but when I plug my 37820_p2n_a22 ecu in it sounds better should I be running that ecu on a b16? It plugs right in but the other ecu I need the harness for with v tech is a 37820_p28_a02
the p2n is from an obd2a HX. it will NOT have proper fuel maps for a b16.
the p28 is from an obd1 ex/si. it too will NOT have proper fuel maps for a b16 unless it's been chipped to have them
There is no H or a space in the term VTEC.
If you don't have emissions in your area, running the p28 chipped to p30 specs (the oem b16 ecu) with the conversion harness is the way to go.
H
how do I makey own post ?? Thanks
go to the main category list, and in the top right corner, there is a Post New Thread icon in blue
