I got a 94 accord dx and want to swap to something with a little bit more power which engine would be the best that will possibly bolt right up with min work ...sorta new to hondas... id appreciate it
im with rabbit. if your motor is healthy i would just turbo it, run about 7psi and you will have more fun the any basic motor swap. but if you just have to swap, the h22a is the way to go as far as ease for that car.
