Here's a little peek at the mounts not finished with the trans mount but this was a stopping point for a little bit. I decided to just completely cut out the stock driver's mount, it gave me another 1/8-1/4 inch of clearance for the crank pulley which is a lot for this particular swap. I'll take some more pictures as I finish the trans mount. Also I'm going to close the driver's side mount in with some sheet metal to make it look a little more decent.
