D16z6 full swap.: hbeam rods low comp foreged pistons for high boost . 440cc injecters. Stock cam or stage 2 cam for low power. Titanium valve springs . Forged low compression turbo pistons . Cat back exchaust 2.5 to 3 inch for turbo. Tell me what u think?
What's the stock injectors' cc? I'm just worried those injectors will max out with a turbo and built bottom end for higher boost. Guys run 1000cc injectors on stock K motors and 16-22lbs of boost. 750cc injectors max out on those set ups pretty easy.
