97 Crv H22A and tranny swap
elchuecoEh2
I was wondering if i could use the trans for the h22a for the 97 Crv AWD...if so what are the steps to get rid of the rear diff or should i just take the shaft off???...i know i can use the rest of the stuff like mounts for a ek h22...am just stumped on tranny and the stock AWD system
No . No . What ? And No , buy a different chassis , but in theory yes you can remove all the awd stuff and make it fwd but why , and yes probably can h22 swap it but again ...
Hunt for parts that match up with putting an H drivetrain into a B series car- most likely H into Integra mounts. Just pull the rest of the AWD hardware, make sure nothing is hanging loose, and put the wheel end part of the CV shafts into the rear hubs with their retaining nuts so that your hub structure doesn't back out.
wont you lose ac and power steering with an h22? why not b20vtec? just bought a crv so im asking myself these questions as well.
