autox19
so everything is going ok except when I push in the clutch while driving, it idles about 1800 to 2200. then I "Blip" the throttle, all is well. (~800 rpm)
Throttle cable isnt sticking as the TPS voltage shows it is at "closed" position for the Throttle. Happens warm or cold. it doesnt hunt, it stays right at the given RPM until I blip the throttle. i.e. if it idles at 1934, it stays at 1943 until I blip the throttle. it is not really intermittent as I would say it happens 90% of the time.
Engine JDM B16 ODB0 with ODB1 Dizzy and ECU with Crome.
Odie
B16 Fiat X19
Odie
B16 Fiat X19
