CT FS: OBD1 tuning set up
Status
Not open for further replies.
Briansol
Admins
Admin
VIP
I've been cleaning out the garage and ran into my box of old tuning items that i just don't ever see myself using.
These are all from the early/mid 2000s and i'm sure things are different today, so consider this a potential old-school package.
I tuned about 4 cars with this setup, wideband was only used for turning purposes, not in the car full time.
i assume it all works, but i can't be sure of it-- i haven't used any of it in over 10 years. It all worked perfectly at the time of storing it and it's been in static bags in a relatively climate controlled area (my garage attached to my house) since.
Taking reasonable offers for the whole set up. Not looking to part it out at this time. This is well over $1000 worth of equipment and can be used with Hondata s200, crome, etc obd1 style tuning solutions with obd1 chip-burn setups.
OStrich
Romulator
pocket programmer
another chip burner, i forget the brand but it was from moates
a bunch of obd1 chips.
keyspan usb to serial port converter that properly gives it an IRQ.
data logging cable with board solder piece
LM-1 wideband o2
20170604_212909.jpg 20170604_212923.jpg 20170604_212937.jpg 20170604_213032.jpg 20170604_213054.jpg 20170604_213046.jpg 20170604_213019.jpg 20170604_213010.jpg 20170604_213005.jpg20170604_212956.jpg
OStrich
Romulator
pocket programmer
LM-1 wideband o2
View attachment 26098 View attachment 26099 View attachment 26100 View attachment 26101 View attachment 26102 View attachment 26103 View attachment 26104 View attachment 26105 View attachment 26106View attachment 26107
How much are you asking for the chip burning equipment
With the chip burner stuff you're selling can I make a base map on my RTP ECU and burn a chip from that
This doesn't include any software. You'll need to get a copy of crome/etc to build a map and then publish it out to these tools to do the chip burning.
I'm just trying to figure out if I should go Neptune RTP, or old-school. The issue is they're all about the same price, except for hondata s300v3 (which is still the most expensive, lol.)
Status
