Easiest way is to get the same motor. Yes, a CRX did come with your motor too but not all CRX models are the same....which means some options need more work/modification to swap in. If you have little experience with car work (and Internet searching for that matter), get same motor that is the same year as your car or newer.I threw a rod through my block on Civic DX hatch 1.5 L d15b2 I was wondering if I could use a block from a CRX from the same three-year period that transfer in and out
