i do
lol
1 check the frame, anyone going to buy it is gonna look at the frame, at least if they know anything about toyotas they will... if the frame has rot to the point that there are holes in it, then its gonna break some time in the future...
if it has no holes, then hit it with a hammer, if it breaks then it was gonna get a hole, if it sounds like you hit a soda can then the frame is dumping, if it sounds like you hit solid metal, then commence with your work...
2 what year is it? if its a 3.0 liter v6, good luck
these had some sort of recall from toyota on the heads, i guess they pop head gaskets, and if they did not get the recall done then the lower end will prob be cooked... lots of knocking and such...
another note... these motors ALONE go for up to 2500 or 2700
they are kinda hard to find as well, i did a job on a toyota 4 runner and ended up finding a truck with a blown auto trans that i got for cheap, and robbed the motor...
toyota trucks are known to be good runners and dependable, but their flaw is rot and rust... most toyota owners are aware of this, but other people just looking for a truck will think twice when they see the bed all rotted to shit... and good luck tryin to find a decent bed for a reasonable price...
other than that...
the v6 motors are all about the same, some diffrences in electronics like dist and knock sensor, but you can make electronics swaps for that...
can;t think of anything else off hand
easy trucks to jack up/lift
