will an obd1 engine harness function in an obd2a car?
Sinner
I have a 97 integra and I want to swap in a obd1 engine that comes with a obd1 harness. I no longer have an obd2 engine harness. So my plan is using 97 integra w/ obd1 engine and harness engine harness controlled by obd1 ecu which is connected to an obd2->obd1 ecu harness.
Thanks,
Nick
yep, that'll work. i dont know if this is required where you live, but here, on obdII vehicles, the diagnostic port is checked at inspection time. you might want to look into that.
Quoted post[/post]]
Isn't the port in the cabin though...if so, shouldn't make a difference if you just use the OBD I engine harness. For the tegs the harness are pretty much the same.
yea, everything will plug in and run fine. but when the diag. port is hooked up to the odbII computer checker thing at inspection time, the odbI ecu wont communicate with it. he should check as this could become a hassle for him at inspection time.
in relation to this subject will an obd1 engine harness plug into an obd2b civic/teg?
just thought i would ask....
*not trying to thread jack*
just more info for other readers... :mrgreen: :mrgreen:
it will only work for obdII intergras. the obdII civic's harness doesnt split at the firewall on the passenger side like earlier civics and integras.
im using a obd2 engine harness on my b16 in my EG. everything plugs in and runs. minus the injectors i had to put obd1 clips on it but its all the same for everything else. i think you can even plug the obd1-2 stuff into the harness. the alt, dizzy and all your sensors should be the same plugs and everything.
