Go Back   HondaSwap Forums > Members' Corner > Racing and Driving Techniques
Facebook Twitter
Another CRX dirt track racecar...
This is a discussion on Another CRX dirt track racecar... in the Racing and Driving Techniques forum
Originally Posted by edwoods17 We are in Alabama racing civic hb (dirt track) Could use some helpfull input and tips . If there is any way to contact you that would be great. Or you can email me or call me edwoods1972@yahoo.com and can also ...
Old 05-25-2010, 06:24 PM   #176
teamrrtjoker's Avatar
Originally Posted by edwoods17 View Post
We are in Alabama racing civic hb (dirt track) Could use some helpfull input and tips . If there is any way to contact you that would be great. Or you can email me or call me edwoods1972@yahoo.com and can also give you my number or I can call you. Thanks Ed
email sent...
teamrrtjoker is offline   Reply With Quote
Old 05-26-2010, 10:25 PM   #177
so the crx got a new body and engine harness out of a 95 gsr integra, also bought a gsr timing belt and water pump to go on tomorrow, try andget the cooling in the happy range by not forcing the water through the motor so fast or cavatating.
the ef hatch has now turned into a ek coupe...
dont have pics yet of cage in, very soon though...fuel cell mounted, seat brackets in, starts and runs, but need to swap over the clutch pedal assembly for the cable tranny conversion...should be tracking by this weekend. really only thing were missing to bad ass...is a hood and a rf fender...damn those bitches are too spendy to put on a racecar...lol
update on the EG...he's all back together and all cocky gonna run out there and grab another first place trophy...
VTEC---A fancy word for my motor don't make power until 5,000rpm.
More redneck stuff at http://redneckracingteam.com/Forum/index.php
Old 05-27-2010, 02:51 PM   #178
INJEN78's Avatar
good shit id like to see more pix man..pm sent
Old 05-27-2010, 03:57 PM   #179
CAFROG's Avatar
Originally Posted by teamrrtjoker View Post
I agree with the tuner...we should not be spinning these over the 7800...but when we are only running 2nd gear we have about 300ft or so wide open out of the corner and not enough time to shift to 3rd before your shutting it down for the next corner...I also think alot of the rpms are due to wheel spin(breaking loose) at about half the distance.
Not sure if I read right but if you have a B16 transmission....this could be a problem for those high rev's and not wanting to shift to 3rd with a corner ahead. The B16 2nd doesn't go as long as a LS transmission's 2nd. You may want to think of that too. But that also means that you will be coming out of the corner at a little lower rpm too. But it would help with the need to have lower revs throughout the track and can save the motor. You are racing it balls out and I would think an LS transmission would keep the motor in the car longer (AKA no snap-crackle-pop motor blew up).
Another plus side is you wont be such high revs out of the corner and that means traction isn't as much as a factor.
But if you have an LS transmission already.....maybe a B20 with a hydro-cable conversion?
"Meow, you know how fast your were going back there?"
My Old B16 Swap (Spring '09) w/CTR cams/springs.
http://hondaswap.com/hybrid-eg-ek-dc...si-b16-286581/
My EH3 with a K-swap
http://hondaswap.com/hybrid-eg-ek-dc...-r-egg-519537/
CAFROG is offline   Reply With Quote
Old 05-27-2010, 04:24 PM   #180
The ef that scattered the motor he was running a a1 cable tranny, the eg is running the b16 hydro, and my crx is running a gsr trans
yeah you read it right...the b16 hydro was the only tranny we could get our paws on during the build. he is on the hunt for a ls hydro now. I am running the gsr cable in the crx and its just about perfect for quickness and top end speed on the straights...but still hitting the rev limiter of 8200 at the end of the straight. right now were are just working with what we got...definitly plans are in the mix if another tranny comes up.
Old 05-27-2010, 07:50 PM   #181
INJEN78's Avatar
well to solve the problem of hittin rev limiter at the end of the straight a little taller tire will fix everything..
Old 05-27-2010, 07:55 PM   #182
thats my next purchase is a 9.0x24.5 or 25 hoosier...little wider for the front and taller
Old 07-09-2010, 10:57 AM   #183
Been busy and updates slow...but you can find most of the info on www.redneckracingteam.com/Forum ...but last week I pulled my first ever sweep of the night 1st heat, 1st trophy dash and 1st main event...gonna go for it again Sat. thanks for all who are following...its only going to get better...the #44 civic now has 3 1st place main events and Hondas have won the last 4 events...
Old 07-09-2010, 10:59 AM   #184
TurboMirage's Avatar
nice
Old 07-09-2010, 11:05 AM   #185
E_SolSi's Avatar
Old 08-05-2010, 11:00 AM   #186
latest...I blew the lsvtec motor...well not reall blew it but lost a bearing somewhere havent looked yet...but still finished 4th with a nasty knock. So I yanked that bottom end and installed a b18c bottom end and then I missed a week of racing but had a friend drive the car for points while I was gone...never on the track or in a racecar before he took 6th in the main with no vtec...last week I won heat, won the trophy dash and took 3rd in the main...track went dryslick bad and had no bite in the corners so couldnt use the power. the gsr bottom end has a way better powerband for anyone thinking about building a dirt track car...the power doesnt come on so strong out of the corner but its explosive corner off to the next turn...So theres only 5 more races left for the season, Im 3rd in points right now with a 24 point spread from 1st to 3rd.
Also due to some unforeseen circumstances Im probably gonna quit racing for a year or so...with that said...I will posting the Crx for sale in a few weeks...$3500 race ready, or $2000 roller minus engine and trans. for another $1500 I have a 2 car trailer also. I have to finish out the season though because I need a big trophy to show for this season. Also I would like to thank HPD for their support in this endeavor...I really hope to see alot more Honda racecars plaguing race tracks across the nation. thanks for all your support too HondaSwap members...couldnt have done it without your advice and help through the build.
Old 08-09-2010, 01:47 AM   #187
Calesta's Avatar
Old 01-29-2011, 06:17 PM   #188
Default nice cars
man you and your friends are crazy about honda's.but that is what this forum is all about. it is nice to see. I am running a 93 integra that i am swapping a b18c into this winter. I race at a local dirt track. do you have any advice or info on car set up, motor, trans, reinforcements would be helpful. i keep getting bet by 2.4 cavaliers. and it is a automatic too. you can seen me a e-mail at herbertiiij@yahoo.com and take a min and check out what we call racing here in new york state. and are rules are not that crazy.
Fulton Speedway > Home
http://www.fultonspeedway.com/Portal...ator_Rules.pdf
thanks Herbie
herbie20h is offline   Reply With Quote
Old 01-31-2011, 07:42 PM   #189
hey herbie20h....thanks for checking out the build thread. I ended up 3rd in points this year...it was a fun season running the Hondas for sure. Your rules are gonna make it a little hard to compete with what ya got...but I think you can do it. first off I'd try reverse stagger on the front...shouls help with corning traction issues...unless you can change out to a manual trans with an lsd...the eg ran a lsd and he was damn near untouchable in the corners and could drive around my crx with an open diff. Im not sure how you keep the rpms up with the auto either but I was running the better part of 8500 at the end of the straights on a tuned p28 with rev at 8700-9200. adjustable struts might help a little too if you can run em...try and keep as much weight on the front left as possible...more air pressure in the right rear will help to give ya a drift effect which helped me to get through the corners faster. With all that said...with the electrical issues at the beginning of the season, and not willing to destroy the car for another spot...the crx was definitly competitive against the best built dirt track cars in our class...go out there and have fun kick the cavi's arses. I did sell the crx got the $3500 race ready...damn Im sad now..racing season is just around the corner. thanks again to everyone for the pointers and following the thread.
CRX Dirt Track Car 32m crx Racing and Driving Techniques 10 03-17-2010 11:51 AM
1993 Honda Civic Turbo 350whp! Showcar/Racecar ! lukeduke Vehicles: For Sale/Trade/Wanted 6 07-30-2009 10:22 AM
Integra Off Road Dirt Track Racing Shock RSS-Bot Auctions 0 01-14-2008 04:43 PM
Honda : CRX CRX Si 1991 Honda Civic CRX Si NASA H1 SCCA SPU Racecar RSS-Bot Auctions 0 12-31-2007 03:33 AM
Building a racecar Turbo6 Integra 7 03-04-2007 11:01 PM
© 2001-2013 HondaSwap.com
