Discuss Swap information, turbo installation, general Honda tech, ecu chipping, and tuning at HondaSwap.com
B20vtec owners I'd like for you to post your 1/4 and set-ups. That involves your tranny too
Okay please do as the title says although to be honest I'd preferr the more stock B20vtecs post there times. Stock meaning stock bottem end the most rod bolts and for the head-the most type R cams(or if you have the full R head-it's still oem) and skunk2 manifold. Please leave as much info as possible. Like your tranny what RPM you take it too. Your WHP & TQ, tires, and chasis. Built B20vtec members you can post too but I'm looking more for the Non-built. Non vtec guys your included too if you want cause I'm still non-vtec, but never been to the track so I'm curious. Thankyou
My vouch threads <a href=\"http://www.hondaswap.com/forums/index.php?showtopic=49209&hl=\" target=\"_blank\">http://www.hondaswap.com/forums/index.php?...topic=49209&hl=</a> <a href=\"http://www.honda-acura.net/forums/traderratings.php?u=32696\" target=\"_blank\">http://www.honda-acura.net/forums/traderratings.php?u=32696</a> <a href=\"http://b20vtec.com/forums/showpost.php?p=123195&postcount=14\ " target=\"_blank\">http://b20vtec.com/forums/showpost.php?p=123195&postcount=14</a> |
Well, I don't have a V-Tec head but I have a B20B with a 99 Si tranny in my 1992 Civic VX Hatchback. I only have taken it out to the 1/8 mile track and the best time I have gotten was a 9.32
#4 | |
#5 |
learning in progress
Ride: 00' Montero sport, 99' lsv civic
well i have an lsv bored.020 over with a b16 tranny in a rex 1/4 14.2 with 2.1 60' @98mph..and it was my 2nd time at the track....its not a b20 but gives you some comparison......
#6 |
Admin with a big stick
Ride: 2003 S2000
What's a B20/VTEC?
#7 |
B20 bottem end from a CRV and a Vtec head ie. b16a2
Basicly the same setup as a LS/Vtec Does anyone have stock HP/lbs ft dyno results of a b20vtec?
Chris 2000 Civic SiR CFB Petawawa, ON Canada |
#9 | |
#10 | |
WHAT?? NINE THOUSAND??
Ride: 2007 Civic LX
What a stupid comparison. quarter mile time is going to be completely dependent on the driver, which obviously is going to vary from car to car/engine to engine. I could have a built to the nuts '68 camaro SS396 and still run 19 seconds if I'm a fucking tool.
#11 | |
#12 | |
Ride: 2007 Civic LX
That much is true, but still. Look at your topic. All you're asking for is setups and 1/4 mile times.
And it's not outrageous, I've seen it happen. There's a '68 SS396 here locally with 15 grand under the hood who can't even run sub-10s in the eighth.
#13 |
not too long ago i posted my 1/4 mile time in general tech and maintnance but i left alot of parts out so here is the simple beast set up.
4 dr gsr b20z bottom end(bone stock) 95 gsr head every thing stock except cam shaft 95 gsr tranny skunk 2 in. manifold(if i still have the gsr aem v2, i would junk the s2 manifold)suc earlier type r camshaft(vtec sounds louder but doubt it made more hp) aem cam gears(in.+2,ex.-6) light crank pulley type r injen cia(should of bought the ls aem v2 for the s2 manifold)just my opinon dc 4-1 greddy sp2 exhaust b&m fpr hondata tune 15 inch mickey thompson slick 13.903@99.43 and 13.9 consistantly w/o slicks 14.2@98 somthing killed-240 sx turbo,golf gti,gm v8 supra,gsr swap civic hatch, jdm h22 91 prelude, and more 4dr gsr(5,000$),b20z long block(1,000$)conversion kit plus conversion labor(200$) intake(215$)header(275$)exhaust(500 $)aem camgears,type r camshaft(100$)fpr(60$)hondata unit(245$)hondata tune(240$)crank pulley(free)s2manifold(free for installing a freinds clutch)slicks(borrowed freinds) and the rest of the other labor i did my self. hope this get you going the b20 vtec route. oh yeah the reliable part, i beat on the motor just like any other street racer maybe even worst and still running like day one for over a year now. |
#15 | |
Ride: 2007 Civic LX
They're just as reliable as any Honda if they're assembled correctly.
#16 |
If you ever want a ball park idea of the 1/4 mile times, hit up this calculator. I find it to be pretty reliable. 1/4 mile et calculator
Spooning Leads to Forking 99% Of the Time. Sig edited by moderator - No pics please |
#17 |
that thing can't be accurate.
doesn't include tire size, gearing, power band, traction, driver, track, external conditions, etc.
Power is nothing without Control. |
#18 | |
I plugged in FJT's WHP numbers from D-series.org, http://www.d-series.org/forums/showthread.php?t=21669 and his 1/4 mile times along with his weight, are shown in this thread... http://www.d-series.org/forums/showthread.php?t=21881 To sum it up, he has 266whp, and car weighs 2600lb. He ran a 12.44. The 1/4 mile ET calculator estimated a 12.454505826295314 Id say thats good enough for guestamating.
#19 | |
B happy
Ride: dohc 95 egg
I plugged in FJT's WHP numbers from D-series.org, http://www.d-series.org/forums/showthread.php?t=21669 and his 1/4 mile times along with his weight, are shown in this thread... http://www.d-series.org/forums/showthread.php?t=21881 To sum it up, he has 266whp, and car weighs 2600lb. He ran a 12.44. The 1/4 mile ET calculator estimated a 12.454505826295314 Id say thats good enough for guestamating. [/b][/quote] Well, Nismo is absolutely correct, you have to figure all those factors in. According to that, I should running a 13.68, which IS possible for 158whp in a 2050lb car, but my tires said otherwise.
95 CX|B16A2| |
#20 | |||
[/b][/quote] Yeah, i never said it was 100% accurate, but its close enough to guess.
#21 | |||
![]() I don't know why that was so funny, but I almost pissed myself when I read that.... I must be stoned... :P
Latest project - 1 fucking fast 99 SI
