Go Back   HondaSwap Forums > Members' Corner > Racing and Driving Techniques
Facebook Twitter
Combating Understeer (was: Combating Oversteer)
This is a discussion on Combating Understeer (was: Combating Oversteer) in the Racing and Driving Techniques forum
Going autocrossing in a EM1 civic, this Sunday. Need some tips on combating oversteer. Setup: 1.25 drop Eibach springs, Tokico Illumina ajd struts, Hawk HPS front pads, 195/55/15 Yokohama S. Drive tires, Stock EM1 Sturt bar and rear sway. So a Street setup. Last time ...
Old 04-08-2011, 08:59 PM   #1
Domi31's Avatar
Default Combating Understeer (was: Combating Oversteer)
Last time they had a 360 degree type of turn that I just strugled with, reading the SCCA form sounds like they will have another one this sunday. Coming out of this turn really gets me off line I know I dont have room for adj on my set up; but I can do tire press and my struts.
Last time had my Tokicos were are on the hardest setting on all 4 corners and ran a stock tire press. Is that wrong? should I have say... front stiff and rear softer or vice versa? or tire press low up front high in rear. Looking to somewhat control the oversteer to keep me turning in hard and overshooting messing me up for the next turn.
***EDIT I AM UNDER STEERING***
-92 civic w/ 97 B18C-R I/H/E traction bar
13.893@ 98.52mph
-95 LS Integra I/H Beater car (Rear ended RIP)
15.62@ 86.27
-00 Civic Si I (my DD) JDM B16 I/E
15.48@ 88.633mph
-02 E46 ///M3
Domi31 is offline   Reply With Quote
Old 04-08-2011, 10:02 PM   #2
reikoshea's Avatar
you're gonna wanna firm up the front struts. If they're already at their highest settings, then you might be screwed
reikoshea is offline   Reply With Quote
Old 04-08-2011, 10:29 PM   #3
Calesta's Avatar
Stiffer in the front for everything... you want to either decrease the turning grip at the front or increase the grip at the rear.
Stiffer front springs
Stiffer front shocks
Softer rear shocks
Softer rear springs
Disconnect rear sway bar (probably too much of a change at once)
More rear negative camber
Old 04-09-2011, 12:03 AM   #4
B
B's Avatar
are you sure you have oversteer? ie, spinning out the back end? loose/etc
it's RARE for this to be a problem in FWD cars.
Most fwd cars PUSH /tight/understeer
B is offline   Reply With Quote
Old 04-09-2011, 11:05 AM   #5
92stoccord's Avatar
Have you recently rotated your tires? Perhaps your fronts got worn significantly faster than the rears, got rotated, and now you have MASSIVE GRIP up front but the back end likes to kick out?
92stoccord is offline   Reply With Quote
Old 04-09-2011, 11:36 AM   #6
Domi31's Avatar
F**k!!
Yes I am Understeering!!! Coming out of the turn and overshooting (pushing). Relized the mistake when I was reading the advise about removing rear sway.
Should I take the above advise and switch it around. Stiff the rear and softer up front? Create more grip in front to keep the car's front from plowing?
Old 04-09-2011, 12:58 PM   #7
reikoshea's Avatar
yup, softening the front and tightening up the read (/giggle) will get you a little more bite in the turns.
If you've never done it before it will be a bit more squirrely than you're used to. But having an FF that has very little oversteer is one of those things that is pretty much impossible, so you do sacrifice some of the solid and planted feel.
Good luck.
Old 04-09-2011, 03:02 PM   #8
Domi31's Avatar
Good luck.
Will try that.
How about Tire press? any tips...
Old 04-09-2011, 03:53 PM   #9
B
B's Avatar
toe-out the front 1 degree \ / so it bites into corners better. increase camber.
both will reduce straigh-line stability.
increase rear sway bar/tightness
learn to trail brake (left foot on the brake while gassing it)
and remember, slow in, fast out.
if you're understeering, you're going to fast.
Old 04-09-2011, 06:05 PM   #10
Domi31's Avatar
Thanks for the advise, will also try the trail brake method
all get rep points for the help thanks!!
Old 04-09-2011, 08:14 PM   #11
awptickes's Avatar
try going slower on that part. You're probably losing time because you're coming in too hot, and trying to mash it while exiting.
awptickes is offline   Reply With Quote
Adjusting Oversteer and Understeer, Suspension Setup phyregod Wheels / Suspension / Tires / Brakes 3 06-28-2009 09:27 AM
Alignment for less understeer-Integra Gnat5680 Wheels / Suspension / Tires / Brakes 8 01-24-2008 11:09 PM
Understeer! :( Ben Civic and del Sol - EG and EK 3 09-05-2006 08:42 PM
hmm, oversteer. 92civicb18b1 Other Vehicle Discussions 5 12-13-2005 10:01 PM
Understeer... ChrisSiR Wheels / Suspension / Tires / Brakes 14 12-23-2003 06:15 AM
© 2001-2013 HondaSwap.com
