From reading some recent posts, it seems like there is some disagreement or ignorance as far as the exact and proper way to downshift using the double clutch method. I'll try to keep this simple as I describe a normal 4th to 3rd gear downshift:
1. Driving along in 4th 2. Depress clutch pedal 3. Shift into 3rd 4. Release clutch pedal Usually the engineers match the gear ratios well enough that this should all happen smoothly, but it can't be perfect all the time. The synchros do a lot of work in order to get the drive gear and 3rd gear spinning at the same time, and the wear on the synchros is what will cause that grinding sound over time. Now, if you want to preserve the life of your transmission, and look (and sound) cool doing it: follow these simple double clutch instructions. Remember, it's called double clutching because you use the clutch twice. 1. Driving along in 4th 2. Depress clutch pedal 3. Shift into neutral 4. Release clutch pedal 5. Blip throttle 6. Depress clutch pedal 7. Shift into 3rd 8. Release clutch pedal If you did it right, the shifter will slide effortlessly into place with no clicking or grinding sounds. If you followed the directions, but still met some resistance getting into 3rd gear, then you are blipping the throttle too much or too little. When you blip the throttle with the car in neutral it causes the engine and transmission to move at the same speed. If you blipped it just enough, this speed will be the same as the axles, too, and everything will come together. An important thing to realize is that the car is not in neutral if the clutch is in. The shifter must be in the middle of the transmission, and the clutch must be released for the car to be in neutral. If someone has told you that double clutching is revving the engine while the clutch is in, they are wrong. That only does half of the work and does not get the transmission up to speed. Here's a "diagram": ENGINE-TRANSMISSION-AXLES/WHEELS The transmission is right between the engine and the axles/wheels, so if you don't get the transmission moving, too, you're not double clutching. __________________
Intake Manifold: a notoriously unreliable engine part often subject to catastrophic failure, usually in conjunction with diamond-plate floorboards. -SCC |
Ride: 93 del Sol Gas sipper
What you said is basicly this
2x clutching is pretty much only used when either your tranny is screw up (syncoros are going, going, gone) or your driving a really old car (ie 60's and stuff like that) __________________
Collin Material Science and Engineering Michigan Technological University |
lol I didn't know that existed, but I'm glad that confirms what I said.
You're right, double clutching NEEDS to be used in those situations, but if you want a sustantially longer lasting transmission, use it in all driving situations. Those synchros do a great job, but they'll last a lot longer if you don't rely on them. __________________
I try to use here and there but most of the time in normal traffic, it is hard to keep up just from a stop light because i am not sure how long you have to keep it in nuetral. About how long should it take.
#5 |
what about double-clutching during up-shifting? same way?
Boosted LS CRX --- Loving the fact that it never runs. After 10G's of work without drivability - seriously considering setting it on fire. |
#6 |
asmallsol - You're right about those cars from the 60s. They don't have synchros and therefore a double clutch is absolutely neccessary to downshift. But your question confused me; are you trying to double clutch when you're accelerating?
To address that and RFHOMI2U's question, do not use this while you are accelerating, there is no point because when you upshift, your engine speed decreases, and there's no need to speed up the engine with a throttle blip. Double clutching is used only for downshifting. I find it to be most useful in parking lots and pulling into driveways. Mostly at slow speeds. This technique makes it easy to downshift from second into first gear when you need to (to pull into a parking lot or parking space etc). Double clutching is not really a racing technique, and is definitely not a drag racing technique. It is just used for a smoother downshift, and to extend the life if your transmission. Most racers don't care about their synchros getting worn because after the race, the transmission gets rebuilt anyway, so there's no need to worry about taking care of the trans for one race. Smooth=fast in racing, but they use a technique that is not really double clutching at all, they simply blip the throttle when downshifting, but don't take their foot off the clutch. A lot of people do that while driving and think they are double clutching. My question is, how are you double clutching if you're only using the clutch once? To get back to those racers, when you're racing, you're just jamming the shifter into gear, with no worry about the synchros. When double clutching, a quick blip on the throttle is usually all that's needed. Just depress the gas pedal all the way down for a fraction of a second, a simple on/off motion. __________________
#7 | |
Basicly 2x clutching IS a racing technique because it make you use Engine braking instead of normal brakes. __________________
#9 |
That is what i ment by coast, and the shifter not leaving the second gear slot because if your syncros are shot like mine, sometimes they dont want to go back in if you talk the shifter out of slot during hard driving but your still free wheeling it because the clutch is in.
#10 | |
Double clutching makes 2 things smoother: First, the actual motion of moving the shifter into gear is easier. This is the whole reason that double clutching was first used. Second, it makes for a smoother transition as you take your foot off the clutch, because everything is spinning at the same relative speeds. My whole point with saying that it's not a racing technique is that double clutching was first invented out of neccessity. The first cars had no synchros, which made downshifting almost impossible unless you used the double clutch technique. I agree that you can use it in racing, but it's slower than the fake double clutch because you don't just jam it into gear. What I was saying before is that for the effect you want "smoother transitions", there is a technique that is just like a normal downshift, but with one extra step: 1. Driving along in 3rd 2. Depress clutch pedal 3. Shift into 2nd 4. Blip throttle 5. Release clutch pedal This technique which I call the "fake double clutch" makes the downshift smooth, but does not save wear on the synchros like real double clutching does. Go out and try all 3 shifts a few times, the regular downshift, the fake double clutch, and the real double clutch. You should have the following results. Pay attention to the feel of the shifter, notice how it is easier to put in gear with the real double clutch. Regular shift: uses synchros to get gear speeds equal (wear on synchros and non-smooth downshift) Fake Double Clutch: still uses synchros to mate gears, but smooth downshift (wear on synchros) Double Clutch: similar gear speeds don't rely on synchros to mate gears, downshift is smooth. Remember, although there's a lot of pedal work, the unique results of double clutching are felt when you move the actual shifter into a lower gear. It should slide right in. asmallsol - since your synchros are shot, you should be able to use double clutching to get yourself back in gear, unless you are doing it wrong. __________________
#11 | |
#12 |
Yeah, you could get it in first gear at those speeds, you just have to blip the throttle for longer to get the engine and transmission up to the relative speed of the wheels.
#13 | |
Admin with a big stick
Ride: 2003 S2000
![]() __________________
#15 |
Ride: 2007 Scion TC, 2005 Suzuki GSX-R 600
Yeah I care man. I mean I am still learning good technique and stuff and down shifting is a have to and this helps a lot. I mean for a car that constantly comes out of second when you let off gas this is useful stuff to save the life of the synchros. Thanks guys for going so into depth on this stuff.
When this is all over I think we should get an apartment together. |
#17 |
hey guys...
you guys said that DOUBLE CLUTCHING IS FOR DOWNSHIFTING... but why and i quote VIN DIESEL in the RICE AND THE FURIOUS after the BIG RACE of the 4 cars does he tell Brian this: "GRANNY SHIFTING, NOT DOUBLE CLUTCHING LIKE YOU SHOULD"... anyone remember right after they were checking out the BUSTED ECLIPSE ENGINE.. dont know why he said that? supposedly they were RACING (UPSHIFTING)... anyone can explain? or should i go to www.movie-mistakes.com and put ANOTHER MISTAKE on that MOVIE...hehe __________________
96 Civic DX HB D16Y7, RS*R Header, MSD Plug Wires </div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE </td></tr><tr><td id=\'QUOTE\'>we drift deeper into the sound, life goes on...</td></tr></table><div class=\'signature\'> |
#18 |
Oh well because Fast N Ferious said it, It must be true. Because i have seen so many rwd cars do burn outs and wheeiles at the same time. Just like Nawwss will make run .000002 second quarters on a stock D series engine or 17's or 18's will make you go faster.
LEARN FROM FAST N FERIOUS BY NOT DOING WHAT THEY DO __________________
#19 |
meh and my buddy watch that movie once a week and point out probably in every scene what was wrong withit and all this stuff. I mean I love the car scenes just because they are cars but really its all bs stuff. The supra would have ripped the fricking maranello up all day but it seemed like he barely beat it and all this other stuff. PURE BS Oh yeah I am making a "remake" using my lawn mower that actually wheelies and spins em going into 3rd and 4th gear, we are using duct tape racing stripes and stuff for it, and using my buddies 83 camaro with t top to do the truck scene with the supra. I will maybe put on the computer when we make it this summer. It will be hella bad ass.
#20 | |
Ride: 2003 S2000
#22 |
The last cars that double clutching was useful was in cars up to maybe the mid 50's latest even the 3 and 4 speed manuals of the 60's had syncros.
</span><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (Pissedoffsol @ Posted: Apr 15 2003, 12:35 AM)</td></tr><tr><td id=\'QUOTE\'>killing a saturn is like beating off and calling it sex</td></tr></table><span class=\'signature\'> |
#23 | ||
Member of the 20 nut club
but thats a whole different story __________________
МОΛΏΝ ΛΑΒΈ |
#24 |
See I always figured that double clutching was a mis-name, I thought it was when you dont use your clutch, I mean I can only really do it in 1st and 2nd well but at the right rpms you can shift out of gear, let your rpms drop a bit and then slide it right into the following gear. just my 2 cents.
#25 |
Why are you bringing up the dead thread alive? seriously this fucking thing is from february!
| Double Clutching while drag racing? | awitron | Racing and Driving Techniques | 19 | 08-14-2003 07:10 PM |
| Double Clutching | teejayc77 | Racing and Driving Techniques | 11 | 06-19-2003 05:49 PM |
| Double Clutching Real Or Movie Made | DylanTheKid | Racing and Driving Techniques | 5 | 06-12-2003 06:35 PM |
| what is double clutching? | h82w8 | Members' Lounge | 7 | 12-27-2002 03:08 PM |
| What is double clutching? | Calesta | General Tech Articles | 0 | 12-27-2002 03:06 PM |
