Go Back   HondaSwap Forums > Members' Corner > Racing and Driving Techniques
Estimate Track Time
Old 04-19-2003, 12:21 AM   #1
d2149 is off the scale
What 1/4 time should I expect with the following set-up:
94 Civic Hatch
b18c1 engine/trans swap
a/c and ps removed
AEM short ram Intake
Skunk2 Intake manifold
dc sports header
custom exhaust work
act 8lb flywheel
act stage 3 clutch
consider the et for an above average/experienced driver
thanks for your help
d2149 is offline   Reply With Quote
Old 04-19-2003, 12:24 AM   #2
SleEPeR_CRX is off the scale
umm, estimating times is lame, but if u drive like me and live on the west coast, with that setup u should run 14.2-13.9 maybe a lower. but get cams and cam gears too:OO
SleEPeR_CRX is offline   Reply With Quote
Old 04-19-2003, 12:50 AM   #3
Everyone I've talked to said to expect low 14 - high 13 times. Problem is, I ran at the track tonight and the best managed was a 15.7 I had 2 other people who are good drivers give a try and they got similar times. Something is fucked up in my engine, now I have to find the problem
Old 04-19-2003, 09:03 AM   #4
Ride:  01 is300, 05 s2000, 03 rx300
pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
sounds like a mad timing issue...
what ecu are you using? was the ignition light set properly?
i would guess you could get 14.5 with that setup..
pills_PMD is offline   Reply With Quote
Old 04-19-2003, 03:08 PM   #5
What do you mean by ignition light?
I believe the ecu is stock gsr, I will take it out and check
I did compression test, got 226-225-225-224 psi
Guess I'll check the timing next
Old 04-19-2003, 06:08 PM   #6
sohcslammer's Avatar
sohcslammer is an unknown quantity at this point
You should be running 6's. Try more stickers. :P
sohcslammer is offline   Reply With Quote
Old 04-23-2003, 09:39 AM   #7
The G37....
get_nick's Avatar
Ride:  Black G37, '07 R6
get_nick has a reputation beyond reputeget_nick has a reputation beyond repute
get_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond repute
 FaceBook
you should expect mid 14's. are you at much altitude. that will KILL your time also.
get_nick is offline   Reply With Quote
Old 04-23-2003, 09:51 AM   #8
i meant was the ignition timing set with a light.. i was probably drunk or something lol
Old 04-24-2003, 07:20 PM   #9
Canadian_GSR is off the scale
Send a message via MSN to Canadian_GSR
Try some slicks, some mickey thompsons on a lightweight 15 inch wheel should take 1/3rd of a second, maybe more with the right clutch and launch technique. When you stage pull up the parking brake with your thumb on the button, lift the clutch pedal enough so it engages and all your gears mesh, i rev to about 8000 (where my shift light comes on) then when the green goes dump the clutch and the brake at the same time and you should run a 13 second pass. works everytime for me.
Canadian_GSR is offline   Reply With Quote
Old 05-05-2003, 08:55 AM   #10
hybridsol is off the scale
Send a message via AIM to hybridsol
do you hate your clutch that much
hybridsol is offline   Reply With Quote
Old 05-18-2003, 09:47 PM   #11
It holds up, I run every weekend on it and havent had any problems.
Old 05-19-2003, 12:08 AM   #12
JDMilan is off the scale
What was your 60ft times??? and List every mod and weight of your ride??
You should be able to hit 13's for sure with a good amount of practice.
Milan
Old 05-19-2003, 12:52 PM   #13
60 ft time - 1.87
95 civic coupe, 94 gsr swap LSD, skunk 2 intake manifold, skunk 2 stage 1 cams, cam gears, underdrive pulley kit, custom air intake box, AEM fuel pressure regulator , DC headers, full exhaust system, kw suspension 15 inch enkei wheels and mickey thompson drag slicks, weighs about 2150 lbs.
Old 05-19-2003, 01:15 PM   #14
sorry, misread the topic, I didn't mean you canadian GSR, but what did you end up running with that low 60ft time though?
I read two topics at once and split my answer, opps....
Milan
Old 05-20-2003, 11:21 PM   #15
13.72 @ 101 mph, forgot another mod, ACT 6 puck clutch
b16 jumped time again, throws a code 4 now t-rexsi HYBRID -> ED-EF / DA 1 12-20-2003 10:36 PM
went to the track tonight DjMcPhatty Racing and Driving Techniques 4 12-05-2003 04:48 PM
d16y7 1/8mile time D15Z1 HYBRID -> EG-EK / DC 4 08-27-2003 01:04 PM
5/25. Gingerman Track Event 98integrals Members' Lounge 5 05-26-2003 08:20 PM
