Go Back   HondaSwap Forums > Members' Corner > Racing and Driving Techniques
First time to the strip......
Old 04-22-2009, 09:43 AM   #1
Delsol94's Avatar
Ride:  94 Del Sol zc
Rep Power: 3 Delsol94 is on a distinguished road
Default First time to the strip......
on friday its inport night at the local drag strip im thinkin of running my car for the first time but im really nervouse, anyone got advise?
Delsol94 is offline   Reply With Quote
Old 04-22-2009, 10:07 AM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
dont miss shift.dont hit rev limiter.dont launch to high/low.dont hit the wall.dont go out thinking your car is the fastest.dont ghetto rig shit just to run.
the usual donts
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 04-22-2009, 10:09 PM   #3
Delsol94's Avatar
Ride:  94 Del Sol zc
damn aight, and im gonna be easy the first run its my daily driver so no full throttle shifts, what u think i should shift at wit my zc z6 with intake/ header/ chipped ecu, i got a check engine shift light at 7 grand but im not that brave for the first run
Old 04-23-2009, 12:38 AM   #4
austin20110's Avatar
Ride:  96 civic coupe, 05 s2k project car with buddies
Rep Power: 39 austin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud of
Send a message via AIM to austin20110
Dont launch to fast and spin or red light
Dont launch to slow and stall.
Warm your tires up and then put your tires in the black tar lines at the starting line.
Originally Posted by packardbell View Post
i plan to modify it to the max and swap out the motor and go fi.
austin20110 is offline   Reply With Quote
Old 04-23-2009, 08:36 AM   #5
Delsol94's Avatar
Ride:  94 Del Sol zc
note.....im running on 14 inch steelies also lol........
Old 04-23-2009, 11:09 AM   #6
The G37....
get_nick's Avatar
Ride:  Black G37, '07 R6
Rep Power: 266 get_nick has a reputation beyond reputeget_nick has a reputation beyond repute
get_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond repute
 FaceBook
you're not going to get any traction.
drop your air pressure down to 25psi (correct me if i'm wrong)
launch when the 3rd yellow goes out. don't wait for the green. you're car isn't fast enough.
it's better to shift slow and grab gears than shift fast and miss gears.
I changed the page layout. let me know what you think. I need feedback.
www.obamacies.com
get_nick is offline   Reply With Quote
Old 04-23-2009, 03:24 PM   #7
Delsol94's Avatar
Ride:  94 Del Sol zc
gotcha
Old 04-23-2009, 04:15 PM   #8
is lol'ing @ you
newb's Avatar
Ride:  '98 Z28
Rep Power: 88 newb has a reputation beyond repute
newb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond reputenewb has a reputation beyond repute
Send a message via AIM to newb myspace
Your close. Every brand of tire is a lil different, so you cant just pick a number. You can hurt traction by droping pressure too much. The best way to set your ideal tire pressure is to do a burnout and look at the marks. The mark should be the full tread width of the tire with NO light spots. Underinflation shows a light center, while overinflation shows a darker center. With a street tire you may need to keep the pressure up pretty high, but theyre not slicks so they dont react the same to lower pressures.
Also, on street tires dont drive through the bleach box. If you do, then you might as well just see how far down the track you can keep the tires spinnin.
Locate approximately as shown
"I'm a bad man." -Cassius Clay
Originally Posted by Battle Pope View Post
this thread makes me facepalm.
newb is offline   Reply With Quote
Old 04-23-2009, 07:40 PM   #9
Delsol94's Avatar
Ride:  94 Del Sol zc
haha ok what else, launch? shift? its tom. morning....
Old 04-24-2009, 11:05 AM   #10
The G37....
get_nick's Avatar
 FaceBook
we already told you how to launch and shift. there isnt' much more to it.
if you have dyno numbers, we can show you your shift points.
www.obamacies.com
Old 04-24-2009, 11:33 AM   #11
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
I ran on my street tires at 20psi. Bump up the rear pressure to 40. More if the tires state that they can handle it. (it will say "max pres. 45psi") or something like that.. Dump extra crap out of your car (spare, jack, cover, etc)
Roll all the way through the water trough, then get the best burn out you can.
When you pull up to the line, there is an order to things.
Pre stage: First set of bulbs at the top of the tree. Pull up slowly until the first set of lights lights up and STOP. Wait for the other car to do the same (Or vise versa if he goes first.. Wait for him to light up the first set, then you pull up and light them up)
Stage: After both pre stage lights are lit, pull up until the stage light (second light on the tree) lights up and STOP. After the second car does the same, (or vise versa) after that, be ready..
After the top two sets of lights are lit, the tree will more than likely have three bulbs light up in half second incraments, then its time to get gone!
Pre stage, Prestage
Stage, Stage
LIGHTS
LIGHTS
LIGHTS
GO!
Aim to launch right AFTER the last set of bulbs lights up before the greens.. You will be aiming to leave the line exactly half a second (.500 reaction time) after the last yellow bulb lights. If you leave before the green lights, you will pop a red light and your run is shit.
While you are in line waiting to run, watch the tree and get used to how it works, timing of the lights, etc. You can practice reaction times in your head just by watching the tree on other people's runs.
Great reading:
The Staging Light -- Drag Racing
Most of all, have fun. Meet up with other drivers, chat them up.. You never know who you'll meet. If you meet other "honda guys" out there, get to know them! They usually have a ton of spare parts laying around!!
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
phyregod is online now   Reply With Quote
Old 04-24-2009, 03:16 PM   #12
Delsol94's Avatar
Ride:  94 Del Sol zc
thanks alot man that was helpful
my ef at the strip desert-storm CRX Civic and CRX - EF 4 02-26-2008 12:22 PM
i guess i wont be going back in time any time soon.... BodyDroppedNikes Members' Lounge 8 03-14-2007 09:39 PM
Long time reader...first time poster KidGusto Members' Lounge 7 09-01-2006 08:34 PM
B18A1 Crx, we went to the strip! phyregod Members' Lounge 0 07-10-2005 03:54 AM
