Ride: JRSC B20/vtec DC, Nissan Xterra SE
well i have never in my 28 years been to a drag strip, and i decided to go tonight. heres the dissappointing story... maybe some of you guys can give me some advice about my driving and about the car.
i was at moroso (now officially palm beach international raceway) at sea level and about 70 degrees. my reaction times suck and they vary a lot .819, .082, .668, .914, .482.... etc.. any tips here? i almost feel like i was thinking too hard about it on the tree... if that makes sense. my 60 ft times also sucked, i had a hard time getting traction, and i thought my toyo proxes4s were pretty good and about the 1/4 mile times.... for one thing, my car is slow. i knew it was slow but its slower than i thought. its a b20z block all stock internals, the b16a head has gsr cams and crower valvetrain. i have a knock off 4 into 1 header, no cat, and a crappy 2" muffler shop exhaust, with a resonator and quiet muffler. on the intake side its a hondata im gasket, oem type r im and tb, with ebay piping. clutch is weak and slipping a little bit, but im not going to blame that too much. transmission is a gsr with open diff, nice smooth shifting tranny. ive got a fuel rail and fpr, the motor is untuned, running on a b20vtec basemap that seems to be a little rich. i couldnt even get out of the 15s i was between 15.2 and 15.8 every time. i was at 90mph all night. weak i know...do you guys think its so slow mostly because of my driving, because its untuned, or what? could the 2" exhaust be choking it? any tips or suggestions? |
Wiring Guru
First off, your reaction time has nothing to do with your ET. You can sit there for a minute if you want to. Time doesn't start until you start moving. Many suggestions for you: Try lowering the tire pressure down to 20. Feathering the throttle on the launch, get the car tuned, etc. Mph is there for mid 14s for sure.
www.JKOBD.com The Original OBD Harness Guru ~ Auto ECU Conversion Harnesses ~ Worldwide traveling Tuner 10.10@152 with da clutch slipping 00 Turbo Civic Street car - ITR Tranny FTW |
#3 | |
!!YTINASNI
Your reaction time will get better with experience. Get a little less adrenaline pumping through the veins and calm down a tad, and it'll take care of itself.
Those times are decent for a B20 DC.. They can get a little better but not by much. As far as 60' times, get a pair of slicks on some super light weight wheels. Personally, I ran "sticky" street tires with a good burn out at 20 psi front, 40 psi rear (for reduced rolling resistance throughout the run). Only because I was too cheap and lazy to buy a set of slicks to swap out. The car was my daily driver. Making the car quicker = weight reduction. Before track night, remove the passenger seat, rear seat, spare, jack, trunk carpet and sound material, etc.. Things that can be removed and replaced with ease without damaging the car. Of course any speaker boxes or extra equipment like that.. Every pound helps. If you're running 15.2 right now, a pair of slicks will bump you into the 14s for certain. __________________
Ride: 88 Honda Civic HB
Do you preload your clutch? If not, that can help a bit as far as traction goes.
#5 | |
Ride: gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Fixing the tune should help out a ton. I used to be running extremely rich, and just a street tune done myself helped so much on the ass dyno.
93' dx hatch jdm b18c - jrsc 8psi s300 440cc RC's |
#6 |
thanks for the help guys... after last night im much more motivated to go get dyno tuned. ive already talked to a reputable local tuner so ill set it up soon. i was really hoping for low 14s last night and was dissapointed with low 15s instead. i mean hell this guy i know was there that ran a 15.2 in a DC with a ls motor with bolt ons. and here i am with a b20vtec with a gsr trans running the same time lol. i only live like 25 mins from the track so i will go back and practice again on a slow night.
what kind of 60 ft time can i really hope for with my toyos aired down and the perfect launch? about the weight reduction thing, i dont really want to have to do that. i like having power steering, ac, and a full interior. i didnt even take out my system. after tuning and some more practice im hoping for at least low 14s with the solobaric still in the trunk ![]() |
#7 | |
!!YTINASNI
I'm not saying to gut it and make a track car.. passenger seat is 4 bolts, rear seat is i think 2 bolts.. Just the easy to remove/replace stuff. Certainly the speaker box.
#8 |
hes not saying to keep it out for the rest of your life, but if you wana shave some tenths of a second off i would take out whats easy to put back in when you go to the track.
#9 |
2.3 is actually respectable for 0-60 on street tires; pretty much seems the norm.
The lowest I've heard is around 2-2.1 on street tires at like 15psi; preloading the clutch. __________________
#10 |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
explain preloading the clutch please.
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
#11 |
Pretty much cooking the clutch
![]() But how most people do it is pretty much use your e-brake to keep the car moving and rev up to whatever rpm and let the clutch up a little...feathering it of course....it's really just reducing the harsh engagement when letting the clutch up. Here's a vid of Bisi and you could see his car jerk and squat a little when he preloads the clutch: __________________
#12 |
so basically you're engaging the clutch just enough to not move, so that when you do want to move the engagement process is already started and there for less harsh?
BTW good info guys |
#13 | |
..is grounded.
Ride: '84 buick (rusted)
what'd he have in that? |
#14 |
All-motor F22A Accord engine. It was carbureted and made around 430whp, he has since switched to individual throttle bodies and methanol.
#16 |
wwtdd?
unfortunately thats what it does.
DO NOT REMOVE YOUR AC. just make sure it's all off. only stupid ricers remove ps and ac, and think it makes them faster. get an lsd and some slicks or drag radials, a good header and exhaust. some itr cams a killer tune, low 14's high 13's will be easy. __________________
Warning: If you are reading this then this warning is for you. Every word you read of this useless fine print is another second off your life. Don't you have other things to do? Is your life so empty that you honestly can't think of a better way to spend these moments? Get out of your apartment. Meet a member of the opposite sex. Stop the excessive shopping and masturbation. Quit your job. Start a fight. Prove you're alive. If you don't claim your humanity you will become a statistic. |
#18 |
Administrator
Ride: 318ti, dakota, genesis 2.0t
first and foremost, proxes suck. lol they aren't a good tire at all. Worse, they aren't a drag tire by any means. so, the fact that you got a 2.3 out of 'em is actually pretty good.
how to drag on street tires (or, how to drag on a car you have to drive home)
#19 |
wwtdd?
good diagram.
basically if you are drag racing correctly, you are going to break shit. __________________
#20 |
is lol'ing @ you
You gotta be careful when your settin your tire pressure. A lot of ppl drop too far, and dont realize theyre bein counter productive. If your pressure is too low, the center of the tire will lift and reduce your contact patch. The best way to find an "ideal" pressure is too lay down some rubber at different pressure levels. Your just lookin for a nice even color across your track. Too light in the center, inflate. Too dark in the center, deflate.
#21 |
wwtdd?
also, if you don't have enough pressure, you are going to have control problems. your tires will get wobbly, and worse case scenario, the bead will pop off the rim.
#22 |
this is precisely how i got several 2.3 60 ft times back to back anything more than 3000 rpms and the tires spin all the way through first and halfway through second. i was just a little dissapointed cause there was another guy there that was hitting 2.1-2.2 with his integra on street tires.
#23 | |
wwtdd?
| Track Time | capricefrk013 | Members' Lounge | 33 | 09-19-2008 09:51 AM |
| my first time at a track what do you think?? | SoSlo | Forced Induction | 9 | 10-09-2005 04:26 AM |
| I went to the track for the first time.... | spectacle | Racing and Driving Techniques | 21 | 07-02-2004 03:36 PM |
| First time at track | highperboi | Racing and Driving Techniques | 1 | 04-06-2004 03:34 PM |
| Track time!!! | Frankie P. | Members' Lounge | 0 | 10-18-2003 11:26 AM |
