Go Back   HondaSwap Forums > Members' Corner > Racing and Driving Techniques
Facebook Twitter
has anyone drifted their Honda?
This is a discussion on has anyone drifted their Honda? in the Racing and Driving Techniques forum
Originally Posted by 95b16coupe the reason you cant "drift" in a front wheel drive is because you can't control the momentum. you start a slide and just slide until you run out of speed. you can't really steer it either. thats why rwd dominates most ...
Closed Thread
Old 05-22-2009, 05:16 PM   #26
civicsiserge's Avatar
Originally Posted by 95b16coupe View Post
the reason you cant "drift" in a front wheel drive is because you can't control the momentum. you start a slide and just slide until you run out of speed. you can't really steer it either. thats why rwd dominates most motor sports. the power wheels aren't used for steering.
you can "drift" an evo before you can drift a civic.
obviously...i'm not talking about pro drifting or taking my Civic to a track and drifting lol...I'm talking about just having fun, like a 45 degree turn where you just pull the e-brake and straighten out when you need to by accelerating...I was going pretty fast, so i'd pull the e-brake, accellerate and pull the e-brake again cuasing my rearend to slip out more. maybe I should take some videos so you can see what i'm talking about. It's not really drifting...more like powersliding. I have an mr2 that I used to drift but it only works when it's wet cause it's a mid engine car and it's stock.
civicsiserge is offline
Old 05-22-2009, 06:01 PM   #27
Jizared97's Avatar
Your going to have some serious flat spots.
Jizared97 is offline
Old 05-22-2009, 06:48 PM   #28
hatukazi's Avatar
I used to do a pretty good drift impression at my dads house (1/2 mile driveway ftw) on the snow, double S corners dodging trees and boulders.
feather the throttle like in drift videos, and dont be solid on the e-brake just bump it to start it sliding and and bump it again when you want to change the direction of your slide.
it was wwaaaaay easier to drift the 240 though.
hatukazi is offline
Old 05-22-2009, 06:59 PM   #29
95b16coupe's Avatar
it's not even power sliding really. it's just locking up the rear wheels. power sliding is when you use the power of the wheels to cut it loose.
95b16coupe is offline
Old 05-22-2009, 10:50 PM   #30
It's all good i have a cousin that works at the tire factory so I get deals.
Old 05-23-2009, 12:51 AM   #31
E_SolSi's Avatar
E_SolSi is offline
Old 05-23-2009, 01:44 AM   #32
Old 05-26-2009, 09:56 AM   #33
awptickes's Avatar
You can drift a honda civic, trust me.
Just put it in reverse.
awptickes is online now
Old 05-29-2009, 11:21 PM   #34
i seen an element drift, it was at the drift mb even this year (drift at the mytle beach speedway)
the definition of a drift is when the slip angle of the rear tires exceeds the slip angle of the fronts, so techniqually you can drift a big wheel if you want.
frodotoolbox is offline
Old 06-08-2009, 11:33 PM   #35
92stoccord's Avatar
Guilty.
I miss my explorer. I hate all the fuckers around here that are like "I need 4wd for the winter!!!" the only thing 4wd will do is get your ass out of a drift easier. Try learning how to drive. That explorer would do whatever the hell I told it to. I really don't like having fwd in the winter. Plus my E-Brake sticks, so it's sort of a one time use thing right now.
92stoccord is offline
Old 07-25-2009, 09:59 AM   #36
the sol man's Avatar
so technically all i got to do is pull the motor from my del sol and put it in the trunk... mwuahaha
drift away!! lol
the sol man is offline
Old 07-25-2009, 10:18 AM   #37
awptickes's Avatar
No, all you have to do is put it in R, turn your head 180deg, and stomp on it.
Old 07-26-2009, 06:16 PM   #38
it happens all the time in S2ks that go autocross. happens atleast once every meet. ahahahahaha
buttered corn is offline
Old 07-26-2009, 07:16 PM   #39
B
B's Avatar
why is this useless topic being disucssed?
B is online now
Closed Thread
Tags
2000, civic, drift
My car drifted.... Airjockie Auto Multi-Media 27 04-18-2004 01:27 AM
© 2001-2013 HondaSwap.com
