Go Back   HondaSwap Forums > Members' Corner > Racing and Driving Techniques
Horses v. Torque in Racing
Old 04-21-2009, 09:46 AM   #1
kriz's Avatar
Ride:  '02 Honda Accord EX Coupe 6-Cyl 3.0L
Rep Power: 9 kriz is a jewel in the roughkriz is a jewel in the roughkriz is a jewel in the rough
Question Horses v. Torque in Racing
Sorry if this seems like a dumb question but I've never quite understood how the two relate to racing/overall car performance. I mean, I've read tons of articles on the difference between horse power & torque. Correct me if I'm wrong but hp is essentially the amount of raw power the engine can output while torque is the engine's ability to turn that power into rotary force thus spinning the wheels. Or at least something along those lines.
In any case, my question is how does hp and torque affect your car's performance? Will an engine with higher torque than hp perform better?
EDIT: Just realized this isn't really a racing or driving "technique," but it does relate to driving/racing. Sorry if this is the wrong area for this post its early in the morning my brain doesn't come on until 10a
kriz is offline   Reply With Quote
Old 04-21-2009, 09:52 AM   #2
Crx Kid22's Avatar
Ride:  87,88 crx
Rep Power: 5 Crx Kid22 will become famous soon enoughCrx Kid22 will become famous soon enough
horse power is just an equation its torque=5252xhorsepower/rpms
you can offset your hp greatly by maxing out rpms thats why every other country uses kilowatts hope this helps
Crx Kid22 is offline   Reply With Quote
Old 04-21-2009, 09:55 AM   #3
Crx Kid22's Avatar
Ride:  87,88 crx
how do you edit?
Old 04-21-2009, 09:57 AM   #4
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
As CRX kid said, HP is attained through the assistance of gearing. Power output is what really matters, kW ftw.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 04-21-2009, 07:16 PM   #5
kriz's Avatar
So... more torque >> more hp??
Oh and Crx Kid you can edit after you become a junior member, there's an "edit" button on your posts
Old 04-21-2009, 07:39 PM   #6
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
o_0
HP=Power, kW=Power; they're just different measurements(1hp=746W).
Torque is what can be had through gearing. HP stays the same. When you build your motor, you're looking to increase torque across a desired power band. More HP=faster car as it's an equation of how fast the vehicle will move over time.
What people fail to realize, any time you're gaining torque, HP is also going up. Do not confuse this with peak HP. You can increase torque in the mid rpm band, and have no increase in peak HP, but the HP in the mid band will go up.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 04-21-2009, 07:44 PM   #7
Crx Kid22's Avatar
Ride:  87,88 crx
horspower is a measure of tourque... and rpms
Old 04-21-2009, 07:47 PM   #8
K2e2vin's Avatar
And the definition of horsepower is???
550ft-lb per second. This was derived from horses being able to pull 550lbs of weight one foot in one second. It's a measure of work.
Yes, it's derived from tq*rpm/5252, but it also means something. They didn't just randomly make up an equation.
RIP
Old 04-21-2009, 09:13 PM   #9
B
Administrator
B's Avatar
Ride:  318ti, dakota, genesis 2.0t
Rep Power: 403 B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
at the end of the day, its the total area (limits in calculus) under the torque curve for all rpms, and taken into consideration each gear's rpm drop and pull...
tons of math... heh
hp and torque lines always cross at 5252. thus, diesels (and other low rpm motors) that redline before 5252 will NEVER have more horsepower than torque.
the ideal power car is based off gearing and horsepower AND torque.
a shift at horsepower peak that lands on torque peak through all 4-5 shifts (5 or 6 speeds) is the most effect use of the power band.
Originally Posted by Airjockie View Post
I got plenty of duck tape, but no penguin tape...
B is offline   Reply With Quote
Old 04-21-2009, 10:36 PM   #10
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Back to basics.
Torque is a measure of force.
Horsepower is a measure of power.
Look at the metric unit measures. Torque is measured in Newton-meters. Look up the specs for any car outside the US- you'll see torque listed as "N-m".
Power is a measure of the application of force over time. Metric power = watts = newton-meters per second, or N-m/s.
Breakdown:
force = 1 N-m
power = 1 W = 1 N-m/s
Torque is your measure of raw pushing ability. That's why you see all the larger engines having higher torque numbers than smaller engines. They generate more force. As rpms rise, power goes up because you're able to apply that force more often in the same period of time. If your torque output on the dyno looks like a flat line, your power output measure will be a perfect slanted line rising with engine speed.
Power is what ultimately gives you the measure of how much work can be performed in a period of time. The more power you have, the more potential you have for faster acceleration. Because of the previous explained relationship between torque and power, you can now understand that you can have the same power output with vastly different torque outputs. A small 4 cylinder engine with half the torque output of a larger V8 can still make the same amount of power- it just has to spin twice as fast.
So remember...
Torque = force
Power = application of force over time = measure of ability to perform work
Old 04-21-2009, 10:43 PM   #11
Reverend Awptickes
awptickes's Avatar
 FaceBook
SO YOU'RE SAYING VTECH SHOULED BE SET TO 5252???
buhahahahahahahahahaha. I'm gonna watch this seed grow into a tree now.
Old 04-22-2009, 01:14 AM   #12
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
Rep Power: 21 TurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to behold
Send a message via AIM to TurboRex90 Send a message via MSN to TurboRex90 myspace  FaceBook
You cant increase horsepower if you cant increase torque. At least that's what i know what dyno run experiences.
BAHAHA!
Boost is not a hobby, It's pure addiction.
Originally Posted by cjvictoria View Post
nigga... i don't have a bike lol... i have a neon.
Wanna check out my build progress?
http://www.cardomain.com/ride/3029308
TurboRex90 is online now   Reply With Quote
Old 04-22-2009, 03:35 AM   #13
Crx Kid22's Avatar
Ride:  87,88 crx
yes you can if you look at the equation rpms is in it so if you have low torque and high rpms you could have the same hp. think of motorcycles ever seen a 2cycle engine? ever seen a 4cycle engine? well they can both have the same hp because they both have a part in the equation!
have you seen that house guy? hes mean
Old 04-22-2009, 05:54 AM   #14
Rep Power: 4 dcasey12 is on a distinguished road
Basically any engine will have a limited amount of torque depending on how much air and fuel is squeezed into it. So an efficient 3 litre car engine can produce similar torque (theoretically) to a formula 1 , 3 litre engine. Where the difference lies is when the torque is produced, a normal car engine will do it between 2000rpm and 6000rpm, a formula 1 engine does it at 13000 to 18000 rpm. As horsepower is a product of RPM and torque thats how the extra power is gained. An engine produces X amount of force (torque) 4000 times(rpm) per minute and the formula 1 engine produce X amount of torque 15000 times per minute.
Just remember High horse power isnt everything, If your car only produces power over a 2000rpm range and you dont have a close ratio gearbox to suit you will be sitting around twiddling your thumbs waiting for the power to come on everytime you change gear.
dcasey12 is offline   Reply With Quote
Old 04-22-2009, 10:32 AM   #15
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
I dont know, at the dyno when my torque line started to drop because of valve float my HP came to a stop and woulnt get any higher. But maybe your right.
Old 04-22-2009, 01:21 PM   #16
eg'sforlife's Avatar
Ride:  92 Civic LX
Rep Power: 14 eg'sforlife is just really niceeg'sforlife is just really niceeg'sforlife is just really niceeg'sforlife is just really nice
basically torque is used to accelerate and horsepower is used to hold that speed
eg'sforlife is online now   Reply With Quote
Old 04-22-2009, 01:27 PM   #17
AHHVTEC's Avatar
that ^^ hp takes over for torque after you get going good
Old 04-22-2009, 04:11 PM   #18
kriz's Avatar
Ah I see, that makes a lot of sense. Thanks a lot for the explanations guys, you're all very helpful.
Old 04-22-2009, 05:21 PM   #19
K2e2vin's Avatar
Torque is the twisting force and horsepower is that twisting force multiplied by how fast it's moving.
It's better to look at trucks; more torque=haul more while more hp=able to move faster.
RIP
Old 04-22-2009, 07:56 PM   #20
Reverend Awptickes
awptickes's Avatar
 FaceBook
Someone told me once:
Horsepower is how hard you hit the wall, Torque is how much wall you take with you.
Old 04-24-2009, 04:17 PM   #21
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
МОΛΏΝ ΛΑΒΈ
Old 04-28-2009, 10:30 PM   #22
kriz's Avatar
lol thanks, that explains everything
Avid racing torque mounts 94-01 integra dc2 b16 b18 RSS-Bot Auctions 0 03-30-2009 05:17 AM
Anyone like riding horses? jeffie7 Members' Lounge 21 07-18-2005 06:34 PM
People on their high horses totalburnout Members' Lounge 3 11-11-2004 10:33 AM
40 Horses Easy! Panzer_M Members' Lounge 19 05-08-2003 03:08 AM
Can I Get Any Extra Horses? 1fastprelude ECU's, Electronics, and Tuning 22 01-13-2003 04:35 PM
