Go Back   HondaSwap Forums > Members' Corner > Racing and Driving Techniques
SOHC VTEC crossover
Closed Thread
Old 04-12-2009, 04:44 PM   #1
Delsol94's Avatar
Ride:  94 Del Sol zc
Rep Power: 3 Delsol94 is on a distinguished road
Default SOHC VTEC crossover
i jus swaped to a fresh jdm zc d16z6 and i have a chipped ecu, should i be able to feel the vtec crossover thats set at 4500 rpm or no because its a single cam, i dnt feel it at all and dnt know if its hitting vtec
Delsol94 is offline
Old 04-12-2009, 09:33 PM   #2
Ride:  98 civic D Turbo
Rep Power: 6 ihatemyprelude will become famous soon enoughihatemyprelude will become famous soon enough
you should feel it, and hear it the D is loud when vtec kicks in.
ihatemyprelude is offline
Old 04-12-2009, 11:43 PM   #3
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
you're joking right?
1) you're not supposed to feel Vtec when it kicks in. It should be a smooth transition.
2) The D series isn't loud at all. You have to really pay attention to hear it since they only have Vtec on the intake side rather than both sides like the B Series motors. Of course built D Series motors are the exception but in general, Vtec isn't loud on these motors at all.
To add to #1, VTEC crossover shouldn't even be felt on built motors as well. Crossovers should always be as smooth as possible.
Real Eyes Realize Real Lies
B16RacerN2NR is offline
Old 04-13-2009, 12:44 AM   #4
SOHC VTEC at its best
95EGCoupeVtec's Avatar
Ride:  95 Civic EX Coupe
Rep Power: 6 95EGCoupeVtec will become famous soon enough
myspace
i have to disagree on the d series not being loud at the crossover, that is IF u have a short ram intake. mine is pretty damn loud my wife can hear me coming home 4 blocks down the road when my vtec rips, and it is a "lousy" single cam lol. now if u have a stock intake, u aint gonna hear it. b series crossovers are fuckin nuts! they are really loud. puts a single cam crossover to shame.
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Turbonetics t3/t4B (ceramic ball bearing) Super V Trim, Stg 2 .48 A/R
Xenocron chipped ecu
Greddy Type RS bov
Tial 38mm WG
GOAUTOWORKS cast mani, 3" DP, WG dump, & oil lines
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
Aluminum rad/fan combo from GoAutoworks
Competition Clutch Stg5 w/4puck disk
BF Goodrich Drag Radials
Soon to have:
15" Rota Slipstreams
tune by Darren in Baton Rouge, LA
95EGCoupeVtec is offline
Old 04-13-2009, 12:51 AM   #5
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
Ive always heard a B16 solenoid on a Z6 makes vtec pop, but then again ive heard like said above that a good vtec transition shouldnt be heard at all, yes youll hear a difference in the engines note but not a sudden surge in power. The z6 is the only sohc vtec that the B16 solenoid will bolt onto, this doesnt work with the Y8s. FYI
D15Beater is offline
Old 04-13-2009, 01:07 AM   #6
myspace
hmmm, idk about the b16 solenoid on a d16z6. i personally have never heard of that. and no crossover should be felt, if it is then ur have your crossover set at the wrong spot. bc vtec kicks on when your tq curve is starting to drop that way u ahve a constant power, not a drop then and increase that can be felt. the smoother the transistion the better. and of course the louder the better!
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Greddy Type RS bov
Tial 38mm WG
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
Soon to have:
Old 04-13-2009, 09:44 AM   #7
Delsol94's Avatar
Ride:  94 Del Sol zc
ok, well thanks guys, the motor has simple bolt ons, header, aem intake, catch can, greddy exhaust, and a chipped and vtec convertet p06 ecu with vtec set at 4500, it runs fine, jw if i should hear it crossover, its not a wiring issue cuz theres no vtec code so that answeres that, thanks guys
Delsol94 is offline
Old 04-13-2009, 11:57 AM   #8
ohm out your vtec valve, should be around 16-18 up to 30 ohms means shes good.
Old 04-13-2009, 04:09 PM   #9
Delsol94's Avatar
Ride:  94 Del Sol zc
aight will do, thanks
Delsol94 is offline
Old 04-13-2009, 04:12 PM   #10
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
wrong forum/ double post
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline
Closed Thread
VTEC crossover Delsol94 Civic and del Sol - EG and EK 11 04-13-2009 10:38 PM
Where should vtec crossover be set at projectxspeed General Tech and Maintenance 9 07-07-2008 07:45 AM
jdm p30 ecu vtec crossover komat General Tech and Maintenance 10 05-06-2005 03:24 PM
Vtec Crossover & rev limiter mezzmerizzencrx ECU's, Electronics, and Tuning 10 03-25-2004 06:33 PM
vtec crossover RENR General Tech and Maintenance 11 08-11-2003 04:37 AM
