Go Back   HondaSwap Forums > Members' Corner > Racing and Driving Techniques
Facebook Twitter
Tire Pressure
This is a discussion on Tire Pressure in the Racing and Driving Techniques forum
i run around 30-32 psi on the street.. what is a good pressure for the track??...
Old 03-25-2003, 04:38 PM   #1
pills_PMD is offline   Reply With Quote
Old 03-25-2003, 05:11 PM   #2
track as in autox/road course, or track as in 1320?
98integrals is offline   Reply With Quote
Old 03-25-2003, 06:08 PM   #3
La_Pieuvre's Avatar
I ran at 26 psi at the 1/8th mile track last time, i got way better traction
La_Pieuvre is offline   Reply With Quote
Old 03-25-2003, 06:17 PM   #4
sorry. i meant a 1/4 mile strip.
i've heard people go as low as 22 psi, but that seems a bit low for me... 26 sounds nice.
Old 03-25-2003, 06:21 PM   #5
La_Pieuvre's Avatar
yeah, just make sure you inflate it back for the drive home...driving on 26 psi feels so weird, kinda like riding on air cushions. , and my gearbox felt kind of mushy...really a bizarre feeling :P
Old 03-25-2003, 06:53 PM   #6
when i run at the track i run at 15-18lbs on street tires [falken azeni's in my case]... i launch around 6000rpm at the track also... but i also have more torque than you pills [at least i think i do since i have ls/vtec]
in your case pills i would run about 18lbs then try launching at different RPMs to see any improvement's in time or traction
i forgot to add when on slicks i run at 13lbs and launch at 8000RPM
2 litre EG is offline   Reply With Quote
Old 03-25-2003, 10:53 PM   #7
ive heard of ppl running as low as 12psi
Old 03-26-2003, 06:55 AM   #8
let me add also that i run bridestone s-03 pole positions on my rota slipstreams 11.5 lbs when i'm at the track..
2 litre eg.. i think i will try to go 26, then drop it to 18 perhaps.. try 5 K, 5.5 k , 6k etc.
Old 03-31-2003, 09:22 PM   #9
B16RacerN2NR's Avatar
i know my cousin ran 20-22psi on his golf when we went to the track...felt pretty damn good if you ask me...don't know what tires he was running tho
B16RacerN2NR is offline   Reply With Quote
Old 04-10-2003, 12:45 AM   #10
msb
Thumbs down
You can go as low as you want to. You will get more traction, but the tires will have more drag (friction between the tire and the street), wich will make you go slower.
The bottom line is that you need to fins the perfect balance between acceleration (good traction: low psi) and speed (low friction: high psi).
Itīs pretty tricky.... thatīs why some of us engineers work on the motorsports industry!!
By the way, no. I am not one of those lucky bastards working for Honda.
msb is offline   Reply With Quote
Old 04-10-2003, 01:17 AM   #11
Calesta's Avatar
Originally posted by msb@Apr 9 2003, 11:50 PM
[b] You can go as low as you want to. You will get more traction, but the tires will have more drag (friction between the tire and the street), wich will make you go slower.
That's not always correct... on street tires, the carcass construction will cause the tread to cup at low tire pressures, so if you go too low, you'll start to lose your contact patch right where you need it- in the center of the tread. You do have to find that sweet spot, but only dedicated slicks can "go as low as you want". You really have to watch out when you're deflating your street tires for the strip.
Stock Tire pressure for 93 DX Hatch adnoh Wheels / Suspension / Tires / Brakes 4 06-02-2004 08:20 PM
Basic Tire Info pissedoffsol General Tech Articles 0 01-12-2004 12:44 AM
Tire Air Pressure.. JrSiRb16A General Tech and Maintenance 4 07-24-2003 01:57 AM
Tire Pressure eyesonlybob Wheels / Suspension / Tires / Brakes 6 06-17-2003 01:38 PM
Crx Tire Pressure Question sportlinecrx Wheels / Suspension / Tires / Brakes 4 01-05-2003 01:28 AM
© 2001-2013 HondaSwap.com
