| | LinkBack | Thread Tools |
| | #1 |
| HS Troll...And Mod Join Date: Apr 2005 Location: San Antonio, TX Age: 24
iTrader: 0 / 0% Ride: 2001 Honda S2000
Rep Power: 270 | I remember watching fast and the furious (strange way to start) and the dude said "too early". I take it that there is a specific time that is best to hit the NoS to get the best results. What is the best time to hit it? |
| | #6 |
Rep Power: 270 | Well i was thinking about running a 75 shot dry on my lude...if i were to do it, could i just set it up through a toggle switch and then cut it off when im done with my run? |
| | #9 |
| Go fast, Go Cheap Join Date: May 2005 Location: Selinsgrove, PA Age: 24
iTrader: 0 / 0% Ride: Hybrid POWER!
Rep Power: 25 | that was kind of a joke. but i guess it would be helpful to have a larger bottle if you can't refill it half way through the night. Nitrous can be run in many different setups, anything from push button when you need it, i.e. passing on the highway. or in some drag racing setups multistage nitrous is used. so much when in full throttle automatically to keep consistancy plus a push button. like 50 shot and 100 shot or what ev. if you have the resources you will go faster holding the button down the length of the track. a toggle switch would work but you might go through it more.
__________________ Resurrected Sol http://hondaswap.com/auto-multi-medi...ted-sol-60210/ 2003 Civic Hybrid (I'm a grown-up now) www.myspace.com/burdenelectronica |
| | #10 |
Rep Power: 270 | such is life...i did the math on it and there is going to be a lil over 3 grand without the mahle pistons and the turbo charger Between valve springs, fuel rail, fuel injectors, fuel pump, cam shaft, Zex dry nitrous, cold air intake (until i save the money for the turbo and new pistons) and headers (still have the stock cause i JUST did the swap into my lude) Gimmie about a month and ill have all that stuff setup. |
| | #11 |
| Senior Member | #1 You must sleeve an H22 to run forged pistons. #2 Why do you have only 1 camshaft in your H22? #3 Where does the 2nd header go on your 4 cylinder? #4 You sound like the perfect candidate for NITROUS. |
| | #13 | |
Rep Power: 270 | Quote:
#2 I dunno why i said shaft instead of shafts #3 Ive always called headers headers even if there is only one. #4 is that sarcasm....cant really tell #5 Totally forgot i made this thread...sorry it took so long for the reply. | |
| | #15 | |
| Senior Member | Quote:
| | #16 | |
[/b][/quote] No, he said he was running forged pistons. I have never heard of a piston that you can run in the H22 without sleeving it, (edit - I mean forged) henceforth I stated that he would have to sleeve the block, TRYING to help out and prepare him for the cost. So there. | |
| | #17 | |
| Admin with a big stick Join Date: Sep 2002 Location: Dallas / Fort Worth, TX Age: 32
iTrader: 0 / 0% Ride: 2003 S2000
Rep Power: 392 | Forged pistons for stock sleeve H22s have been out for quite a while... I just have no idea if they actually work or not. Some people say they don't. Quote:
| | #18 | |
[/b][/quote] LMAO!!!! | |
| | #19 | |
[/b][/quote] wow thats funny shit | |
| | #22 | |
| FüK-VTEC | Quote:
Spray that shit off the line, y0! | |
| | #23 |
| Member | yes its true that im a noob to these forums, but im NOS certified on install on just about any kit on any import, first a few statistics on the board: fast and the furious is all BS! a stock block can handle half its original power in nitrous amounts flirting with complete stock set up. (ex... h22 stock block 200 hp = 100 shot pushing the line) nitrous set up right should have 2 switches for totall safety a WOT swith by the TB and an arming switch at your reach a simple NOS kit is basically a bunch of grounds and powers that when all hooked up realease small controlled amounts of nitrous into your manifold through solenoids. for 3 1/2 years i ran a 70 shot in my 01 lude never had a problem... never lost cyl. pressure, no fuel problems things you should probablly get for safety, one step colder plugs a fpr isnt a bad idea it is helpfull plug wires with complete stock internals you can run a bottle week np so you ask when should you hit it... its not so much when to hit it... its when not to hit it, dont get on the bottle before 3k dangerous!!! dont waste nitrous through 4th and 5th waste of expensive nitrous and not too good for the block if you use a WOT switch arm it pre launch lock the wheels up and get on it in first, take it through 2nd feel the power, all the way through 3rd and off when your shifting into 4th... dont watch anymore fast and furious its all lies... NOS does nothing in those gears on an import motor making 200hp 70 shot in my 01 lude for 3 1/2 years 70 shot in my 90 si SOHC non vtec block stock internals plugs wires fpr not a single problem... other than the motor torqing so hard i ripped the front motor mount clear off and shattered the tranny case by ripping the rear mount off not to much not too little be safe be smart best yet get a purge aimed over to the right out the windshield and scare away wrx's as they get some NOS in there face while your handin their ass to them |
| | #24 | |
| | #25 | |
[/b][/quote] hahahhaa | |
