#27 |
Ride: 1999 Honda Civic EX
yeah i wish i would have started driving like this at 16! wow ran 11's all day bouncin off limiter! usually run 21's driving my original way! thank god for this forum it has given me more knowledge on "when to shift" then i could have ever imagined!
#28 | ||
Brilliant Schizophrenia
Ride: 91 dodge spirit turbo 14 psi, fmic, 2.5 in exhaust
I just launch in 5th gear. No shifting necessary
![]() __________________
___________________________________ _____ You've come to this battle of wits unarmed Quote:
#29 | |
^^ Likes Bewbies
Ride: Rex, Yamaha Virago, CB900F Supersport
I'd be afraid of blowing up my VTECH on the launch!!! You are brave!
#30 |
My name is Byron.
Ride: 89' DX Hatch w/B16
Set your VTEAACH at like 500rpm, that way your always have that MAD JDM TYTE VEETACH HITTIN Y0!!!!!!!!!!!!!1!!!!!11
^ (dont listen) Dont PM me with tech questions. I will not answer them. There is a hidden message here. "Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details." "In the dice game of life who gets the last roll?" |
#31 | |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
bring that shit home and install it,then run a wire from the nos button to the vtec wire,INSTANT VTEC ACTIVATION,combined with rev limiter for 10secs..def. nets you consistent 9.3's __________________
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
#33 | |
My name is Byron.
#34 |
ambitious...but rubbish
Ride: 91 Si hatch GSR swap
some funny shit going on here
, but seriously if your tach and speedometer are synchronized you can shift without your clutch.also called floating the clutch. __________________
I live my life a quarter mile at a time, thats how far I get before I break down. |
#35 | ||
Driving a 20 year old chrysler is bravery enough. But me? I push the envelope. Rev high so the turbo spools and drop that shit into 5th!
#36 | |
^^ Likes Bewbies
I heard that pouring some cheap vodka in the gas tank would make your car perform like it was an alcohol blown car. I am going to try that and see if I can run 8's instead of 9's with this method.
#37 | ||
I run sailor jerry all day. Fried my clutch cause it just can't take the power!
#38 |
I still know everything
Ride: 89 CRX HF, 96 Accord EX, 88 Dodge Daytona Shelbyz T-tops
Do you mean rev matching and shifting without the clutch. If that's the case, then say bye-bye to your syncros
Formerly the.original.kermit Back from the dead... twice I NEED PARTS!!! http://hondaswap.com/parts-sale-trade-wanted/wtb-1989-crx-parts-161172/#post1079066 Check out my progress... http://hondaswap.com/auto-multi-media/my-1989-crx-project-144941/ |
#39 |
My name is Byron.
When you rev match it doesnt use the sychros, a lot of older cars dont even have synchros, so its a must to rev match, even when using the clutch.
#40 | |
I don't understand the appeal of clutchless shifting. Rough on the trans, plus, if you are looking to get the best times, why not full throttle shift? __________________
#41 |
^^^my brother is an OTR trucker, he uses this method to save his clutch (and leg)from wear and tear, in your car most of the time you end up in traffic and can save the clutch for the races.
#42 |
Truck transmissions can't be compared to car transmissions. Trucks don't have syncros, so there isn't any damage done when you don't use the clutch. also trucks have a lot more torque to tear up there clutch with, so it's a benefit to them no to use a clutch.
#43 |
Ride: 88 Honda Civic HB
Anytime you use the clutch you're theoretically wearing it out.
Clutchless shifting doesn't harm your synchros/transmission at all unless you're jamming it into gear. If you do it right, the car doesn't jerk at all and is very smooth. I've used it a couple of times when my clutch master cylinder was going out and driving my cousin's HB which has a rediculously strong clutch for his setup(using the clutch made regular driving difficult). __________________
#45 |
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
Waste Of Bandwidth.
Yeah caboose. Google Dog-tooth transmission or a dogbox. __________________
YBLEGAL.NET → Profile • Projects • Parts For Sale → Steel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal |
#46 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
when you shift without the clutch in hondas it doesnt ruin anything.unless you grind it or whatever..
you ruin the synchros more by actually using the clutch __________________
#47 | ||
i'm surprised it didn't lock earlier when we were all joking
#48 |
you wear your sycros, because they will be trying to align the gears when you shift, but they can't since your clutch isn't disengauged. Just becasue there is no grinding doesn't mean everything is ok.
#49 |
is lol'ing @ you
Wrong. Syncros work 100% of the time. In a constant mesh tranny, the syncro turns the next gear at the appropriate speed to shift without grinding, rather the clutch is engadged or not.
#50 | |
Sorry, what I meant was that you syncros will be working to align the "dog teeth" which lock the gears to the shaft, although constant mesh doesn't mean constant synchronized.
Constant mesh means all the teeth of the gears are always engaged, but only one is locked onto the shaft at any given time. If you change gears, the input and output shafts have to be synchronized with each other, hence the need for syncros. Quote:
| FS: GSR Hydro Tranny Parts > Shift Forks , Reverse Change Holder , Shift Mechanism .. | D See 2 | Parts: For Sale/Trade/Wanted | 1 | 11-29-2006 11:08 PM |
| shift linkage Shift cable? | Ignorant import guy | HYBRID -> EG-EK / DC | 3 | 02-04-2006 11:14 AM |
| TOP SHIFT | SiR_Redneck | Computers, Games, Electronics etc | 2 | 03-19-2005 12:52 PM |
| where should i shift | 92Gsrhatch | Racing and Driving Techniques | 5 | 03-09-2004 10:32 PM |
| when do you shift? | littlehatch | General Tech and Maintenance | 2 | 12-23-2003 10:07 PM |
