Go Back   HondaSwap Forums > Technical Articles and Reference > Reference Materials
B Series Cam Guide
Old 02-10-2005, 12:41 AM   #26
hey phockers........
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 06-17-2005, 01:06 AM   #27
Rep Power: 14 allgo is off the scale
bump! are u going to post new cams spec on there? Rocket m22, buddy club, blox, ect...
allgo is offline   Reply With Quote
Old 07-08-2005, 06:41 PM   #28
Rep Power: 9 DravenVX is off the scale
i got a question for ya JDMilan. I have a 99 JDM B16A and i have the Skunk2 chip in my P28 ECU. Now the rev limiter is now at 9000 so can i safely take the revs that high without modifying anything else? Do i need some valve springs? oh and I am also getting Skunk2 cam gears soon if that helps? I just don't wanna screw up my engine that's all!
DravenVX is offline   Reply With Quote
Old 07-08-2005, 07:10 PM   #29
Stylus DJ Extraordinaire
integraslut78's Avatar
Ride:  ?????????
Rep Power: 38 integraslut78 is on a distinguished road
Dual Valve springs and titanium retainers are your best FRIEND. You should have started a new thread though and not posted here but hey I am not a Moderator so it's all good with me.
DC Squad Member # 0631
I used to have my rides in this section but there are too many thieves out there trying to jack. I HATE THIEVES
integraslut78 is offline   Reply With Quote
Old 07-25-2005, 08:20 PM   #30
Rep Power: 9 becoming is off the scale
Well as far as you sohc'ers, i personally would not recomend the Zex cam to you. my friend had one and you could barely even tell it was there! I think his air intake had more effect on his motor than the cam did! But as far as the skunk2 cam for the sohc application, i have never know anyone to do it.
But a question i do have for you JDMilan, is that i have a 98 LS bottom end, with a 95 GSR head{Crower dual spring, Ti retainers and keepers, Ferrea stainless valves}. I also have a Skunk2 IM and a crank girdle in the block to help rigidness at higher RPM's, but do not want to spin it highter than 8200 or so...and my dilema is that i have a turbo kit to either put on this motor, or my LS swap i'm putting in my del Sol, and keep my hatch all motor. But can't decide which set of cams to get if i do go all motor in my hatch, because i want to keep a narrower power band{3k to 8k}, but in doing that, i want to see "awesome" power out of a set of cams if i do go that route! What are your suggestions? I also have planned on ITB's for it if i do go all motor also. And FYI this is still a "street car", but with no emisions to worry about down here in Alabama . So i have no worries about that aspect of things, I just want Balls-to-the-wall power!
&quot;Five gears, Three Honda's, And only one fuckin hand to shift them with&quot;
92 eg hatch lsvtec
93 eg hatch z6 43 mpg
93 del sol being re-done completely
becoming is offline   Reply With Quote
Old 08-01-2005, 09:22 PM   #31
In stock condition I would so nay, the stock cams make power until roughly 8-8200rpms. Anything past that wont do you any good. High revs doesn't mean more power unless your cams will produce it otherwise. I would personally set your rev limit at 8200, so that if your wheels do spin you won't put any stress on the motor. Good luck.
Old 08-01-2005, 11:57 PM   #32
If that was directed towards me, I don't follow....lol
92 eg hatch lsvtec
Old 04-13-2006, 06:52 AM   #33
Rep Power: 0 ferrallas is off the scale
QUOTE(becoming @ Aug 1 2005, 10:57 PM) Quoted post
In stock condition I would so nay, the stock cams make power until roughly 8-8200rpms.* Anything past that wont do you any good.* High revs doesn't mean more power unless your cams will produce it otherwise.* I would personally set your rev limit at 8200, so that if your wheels do spin you won't put any stress on the motor.* Good luck.
[/b][/quote]
Then Integra GSR cams best than Civic Si 99, its a good upgrade?
ferrallas is offline   Reply With Quote
Old 04-14-2006, 08:31 AM   #34
[img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
Old 04-15-2006, 10:57 AM   #35
QUOTE(JDMilan @ Apr 14 2006, 07:31 AM) Quoted post
[/b][/quote]
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Its a good upgrade the GSR cams?
Old 04-13-2007, 09:26 PM   #36
Rep Power: 0 JDM-Ownz is on a distinguished road
Anybody Knows the XS POWER Cams??
Specs are:
Intake : 0.461 , 293
Exhaust : 0.468 , 295
I need information or experiences with these cams.
Thanks.
Alex
JDM-Ownz is offline   Reply With Quote
HTML code is On
K series vs. B series Frankie P. Members' Lounge 10 09-16-2003 10:46 AM
Get your Beee series while it last JDMPowersales Members' Lounge 14 08-22-2003 05:18 PM
F Series In A 94 Sol? BlackDelSol HYBRID -> EG-EK / DC 9 06-06-2003 08:58 AM
D16z6 JBHonda HYBRID -> EG-EK / DC 93 01-10-2003 03:23 PM
Can I put a D series tranny on a B block? Calesta Swap Articles 0 01-02-2003 05:59 PM
