Go Back   HondaSwap Forums > Technical Articles and Reference > Swap Articles
H22/H23 Accord w/ AC
Old 11-01-2005, 02:29 PM   #1
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
<div class='quotetop'>QUOTE</div><div class='quotemain'>
i have an h23 in my 94 lx 4door and i keept my a/c
first you will need to leave the a/c compressor hocked up do not disconect it you can work around it when you get the engine out pull the a/c bracket of your block (f22) then put it on the prelude motor it will bolt up then you will use a alternator bracket from a h23 and the power stering bracket from a h22 and all your stuff from the accord will bolt up i.e.
a/c
alt
power steering pump
you will need the belt for an h23 motor to run the alt and a/c compressor
then you will need to just go to checker and check belt fitment for the power steering belt also take the car there so you can keep trying diffrent sizes it is a little bigger then the one for the h23 or h22 and smaller then the one for the accord
thanks
chad
kaoskustoms@yahoo.com
[/b][/quote]
