the OG
Ride: 97 bmw m328, 08 yamaha r6s, 94 suzuki dr350, 73 honda cb350 cafe racer
1. Disconnect the 1P connector from the VTEC solenoid
valve. 2. Measure resistance between the terminal and body ground. Resistance: approx 14—30 ohms 3.If the resistance is within specifications, remove the VTEC solenoid valve from the cylinder head, and check the VTEC solenoid valve filter for clogging. • If there is clogging, replace the engine oil filter and the engine oil. 4. If the filter is not clogged, push the VTEC solenoid valve with your finger and check its movement. • If VTEC solenoid valve is normal, check the engine oil pressure. __________________
Hi |
| Vtec Stuff | jessed | HYBRID -> EG-EK / DC | 12 | 10-16-2009 04:37 PM |
| dpfi to mpfi? | little88hatch | ECU's, Electronics, and Tuning | 6 | 04-16-2006 03:35 PM |
| questions | rushcrx | HYBRID -> ED-EF / DA | 6 | 06-29-2004 11:54 PM |
| good sites for stereo installs | WetWilly | Car Audio / Security / Electronic Accessories | 4 | 08-26-2003 12:28 PM |
