AC2i0v0i0c
I'm putting a 00' b18c5 into a 96 ek and I've heard that since I'm using the itr's ecu I would also need to use the key from the itr and switch the ignition system. Also, trying to get some energy suspension motor inserts. Does anyone know if I buy the inserts for the car or engine? What motor mounts would I also need. I know I would need a rear and driver side mount from a 99-00 si. What mount would I need from the itr?
