00 Civic Heater Blows Cold Air
pkennedy
I believed I tried everything and the heater still blows cold air. Here's what I did so far.
1) Made sure the heater controller moved the heater valve open and close positions. That was working.
2) Checked thermostat is was working. Replaced with a new 1 any way.
3)Disconnected the heater core inlet and outlet hoses and connected a water hose directly to the heater inlet. Turned on water to see if the core had a blockage. Water was coming out the outlet hose.
4) Bled radiator.
I did a H22 swap a year ago I had this prolem with the old engine too. Need help winter is coming fast I need heat.
Hmm.. are both the inlet & outlet hoses on the heater core hot when the engine is running and the heater valve is open?
