shortdahri
Member
I have:
00 GSR Engine put in a 98 GSR Chassis.
00 Engine and Cabin Wires.
Also have:
00 GSR ECU
98 GSR ECU (P72)
00 GSR Stock Dash Gauges
I dont have the 00 GSR Ignition w/ Key that corresponds to the 00 GSR ECU so I definitely have to use the 98 GSR ECU because of the immobilizer in the 00 GSR ECU.
I believe I have to get a obd2b to obd2a wire conversion harness to use the 98 GSR ECU but is there anything else I need to change, convert or splice to get the everything working?
Thanks guys.
Also have:
00 GSR ECU
98 GSR ECU (P72)
Thanks guys.
