00 ls engine into 97 ls
Discussion in 'HYBRID -> EG-EK / DC' started by xintegralx, Jun 19, 2007.
  1. xintegralx
    xintegralx New Member
    I'm getting a 00 b18b obd2b to put into my 97 b18b obd2a integra... I've been told it's a direct swap, using the new motor harness and keeping my wiring harness/obd2a ecu. Any more information? I don't want to go into this and have to spend alot more money than planned. Any info is appreciated.
  2. welfare
    welfare Ancient Member
    New York
    direct swap, but Im pretty sure you have to use your old engine harness.
  3. xintegralx
    Ok, what exactly does that entail? To use the old engine harness?
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just use your cars stock harness and buy a 60 dollar jumper from a to b
  5. xintegralx
    Where can I get the jumper from?
  6. AHHVTEC
    Alabama
    rywire.com just call them and tell them what your doing
  7. welfare
    New York
    Take the engine out of the car, remove all the wires from the engine that you just took out of the car and set them aside, this is your engine harness.
    Take you new engine and take all the wires off it and toss them or sell them
    install the wiring harness you took off your old engine onto the new engine and then put it in your car.
    don't touch your ecu, it does not have to be changed, nor do you need a jumper harness or any other crap.
  8. AHHVTEC
    Alabama
    wrong wrong
  9. xintegralx
    Ok, ahhvtec, why do I need a jumper then? If I am using all the components from my old engine, it should be the same connections... Other than some "tach test" that won't be connected to my ecu anyways... What exactly am I jumping? I'd appreciate more information than just "you need a jumper." Thanks in advance.
  10. AHHVTEC
    Alabama
    the ecu are diffrent obd2a and obd2b are diffrent
  11. welfare
    New York
    Right, but the engine are not different, all he is doing is changing the engine, everything is the same between the engines except maybe the iac wires, he should just leave his stock ecu in it's place and use his old engine harness, it will plug right into the new engine.
  12. AHHVTEC
    Alabama
    oic i got ya yup yup
  13. xintegralx
    ok that's what I thought... thanks for the input guys, I'll keep ya posted after I get the swap done...
