marklar182
Usually I'm pretty good about using the search buttons but there is so much contradicting info out there so I'll ask some experts!
Donor Engine/tranny- B16a2 (390hp turbo) from a 00 Si
Recipient- 93 Civic Si hatch
ECU- P28 chipped w/ Hondata Stage 4b
axles- Driveshaftshop.com 00 Si
?'s
1. Motor mounts. Is this a direct swap or are different mounts needed? I've read both ways so far. Looks like a direct swap to me though.
2. Engine wire harness. Can the 00 Si harness be used? I know it is an obd2 harness but the p28 ecu worked with the obd2 engine. Do not want to swap out the dizzy($$$). Is there any other harnesses that will work? Is it practical to remove the complete harness(from ecu on) from the 00 Si to the 93 Si?
TIA
?'s
TIA
