For starters go out and get a Haynes manual. We used that bad boy to tear down and rebuild a 00 SI.
Unbolt the pressure plate from the flywheel, remove the clutch plate. Check the flywheel surface for damage, resurface if needed. Pull and replace the pilot bearing. Clean the flywheel with brake parts cleaner. Using a clutch alignment tool put on the clutch plate and bolt the pressure plate back on. Tourqe to spec. Change throwout bearing on tranny. Reinstall tranny.
